L Series rear shocks
Bennie you might be interested in this. Late 90's Toyota 4Runner Shocks with Honda springs in L series. Excellent detailed write up here http://www.ultimatesubaru.org/forum/sho ... p?t=110546
If you can fit standard 4runner shocks, then i don't see why a set of aftermarket shocks for a 4 runner couldn't fit either.
45mm lifted shocks for a 1990's 4Runner http://www.toughdogdealer.com.au/4runner.htm
I like that I idea and am glad you've posted that - thanks mate! I'm about to venture the now longer distance to melbs to look for those pneumatic rear shocks, buy with a warranty incase they're dead.Venom wrote:Bennie you might be interested in this. Late 90's Toyota 4Runner Shocks with Honda springs in L series. Excellent detailed write up here http://www.ultimatesubaru.org/forum/sho ... p?t=110546
I'm still keen on seeing if I can hook these up for manual inflation to a set pressure, much like tyres are done. I'm just worried about the age and condition of the units, hence the warranty - at least I'll get a credit if they're dead.
If anyone knows how to tell if they're dead please let me know by calling zero for to won one ate four O three 1
I'm after a few other bits while I've got the ok to spend a little on my subi
Those Hilux front shocks have less travel than the suby ones
IFS fail
the truth is, we will never get boonta travel out of any shock fitted to a standard subaru driveline. The control arms etc just downt allow for it.
Ah - hadn't thought about that! I looked at those pics in the USMB again and I can see where you're coming from Paul.RSR 555 wrote:Those Hilux front shocks have less travel than the suby ones
True that, but I'm willing to work with what Mr Fuji gave us. I had looked into a liberty rear end with shortened control arms to keep the standard track width but I don't know how to go into the strut tower construction in the L's rear guards - I'm not keen on cutting and welding a tower into the mud guard, I would prefer a "bolt in" tower that's concealed in the guard.Alex wrote:the truth is, we will never get boonta travel out of any shock fitted to a standard subaru driveline. The control arms etc just downt allow for it.
Anyway - that's a distraction.
Today I got back to that Vortex - rear pneumatic shocks replaced with the standard L spring/shock combination
The honda springs all have 11 turns of the coil to the subaru's 7 or 8 (can't remember now) and the honda ones a loads fatter too. So a set of spring compressors will be sorted tomorrow before heading back. I'll see how the stock shock goes with this setup - thinking I might still need an upgraded shock in the end.
All that said, I'm still keen for an adjustable setup for different load ratings - if this doesn't satisfy me I'll keep looking for a setup with air that does.
Paul do you see any pneumatic rear's come through your workshop? Keen to know what they look like/serviceability are etc. Keen to know if I could actually setup the manual inflation for different load rates...
Hmmm... I'm sure I'll change my mind about something along the way!
but how many thousand 6 to 24 inch lift shocks for hilux and four runner are there
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Bennie.. I'm thinking I already have a set up here at the shop, will let you know what condition they're inEl_Freddo wrote:Paul do you see any pneumatic rear's come through your workshop? Keen to know what they look like/serviceability are etc. Keen to know if I could actually setup the manual inflation for different load rates...
Well it was a great time away from work - but living the best part of 4 hours from melbourne (read the pick a part yards) sucks!
So it went like this: I worked yesterday morning on the brekky shift, finished super early (lack of people in
) so headed home to pick up the other half - who was still in bed! So anyway basically everything ran late all day - I only had 1 hr in the yard before they closed. Kez came up with the idea of staying at grandma's for the night so we did. Saved a pot load of time and allowed me to spend some more time in the yards.
Went to Kilsyth for some rear struts - only to find that every L series (3) in the yard had their struts taken. Not happy. But I did pick up a complete tailshaft that had 193k on it - better than my 420k+ unit! We then headed back to centre road where we were yesterday. My patient wife hung out in the car doing her cross stitch while I got to work in the yard with my rear shocks:
Started with a set of struts from the front of a honda civic - early to mid 90's unit. Below is the L series rear strut and the honda civic front strut:
After removing the struts here's the springs to compare - Civic on the left, L series on the right:
^ The civic spring is thicker and as you can see has more coils - its also *slightly* smaller than the L's spring diametre but still fits well.
After some playing around with my new spring compressors I ended up with the L shock absorber mounted with the civic spring - a good fit. In the centre is the L spring and the right is the stock civic setup that the spring was sourced from:
And here's my replaced strut setup beside the one that's fitted with the civic spring - that king spring is lose in that pic, its easy to rattle it around unlike the loaded civic spring:
<image deleted - too bloody large>
It took me about 15 minutes to fit the civic sprung strut to Ruby Scoo. Here's a before shot in my "workshop":
And the dodgy after shot:
I think it has settled down a little since that last pic. Going for a drive reveals a much firmer ride and a weird feeling that the rear is now taller than the front, I'll get used to it. After a test over some "local" speed bumps I'm pretty happy with them as the old units would really compress where as these units take the downward weight but resists it coming down - a good feeling that should go well with a load in the back.
I am thinking of having one turn of the coil cut off then heated and pushed flat to create the same top seat shape for proper seating of the spring - anyone know if this is doable? I ask this as the spring is much taller than the original unit and I think it might make ruby scoo sit a little flatter while retaining a decent spring rating - I think she's a little high in the rear but that could just be me getting used to her new look. Having a load might prove that the current setup is just fine like this
Best bit: The struts cost $40, spring compressors and torx/hex keys ~$80 (not so good but needed them without time to shop around). So a good result with some new additions to the kit. Happy so far!
just lop a coil off. no need to flatten it back out again.
maybe paint to stop rusting...
NOW..my next question for you. Your king springs must be a 2wd unit. Mine sat tight in my shocks, not loose at all. I remember brennyv having this problem. (but once you lowered the car onto them they came under load)
i dunno tho
i dunno tho
Nah I found out that the king springs are just standard replacements - not lifted or upgradedAlex wrote:NOW..my next question for you. Your king springs must be a 2wd unit. Mine sat tight in my shocks, not loose at all. I remember brennyv having this problem. (but once you lowered the car onto them they came under load)
I'm sure you'll find that the springs in the 2wds are the same as those in the 4wd units, just that the 2wd shock is longer for the lower mounting point.
Bennie.. sorry to say but the rear air struts I have are the Liberty model not the XT6
No worries Paul - thanks for looking anyway.RSR 555 wrote:Bennie.. sorry to say but the rear air struts I have are the Liberty model not the XT6
Mrs El Freddo says that Ruby Scoo feels more like her commodore's suspension around town now - not as sloppy.
I took Ruby Scoo out of town for a blart at 100km/h to see what she felt like unladen with the larger rear springs - all went well and I was rather pleased with the handling. I'm not sure if I've hit the kind of bumps that induce a frontal "bounce" where it feels like the front end runs out of downward travel at speed but I didn't feel any of this occur and hope that the stiffer rear springs have eliminated this behaviour as I don't like it!
So for a cheap lift and heavier spring rating the honda springs are a thumbs up so far. Need a couple of days off to start moving stuff back to M&D's before we're off to hotham again - that'll test out the load handling, but I reckon its already in the bag!
- TOONGA
here's an interesting read about mazda mx5 / miata adjustable shocks on an L series.
http://www.ultimatesubaru.org/forum/sho ... chux+miata
mind you it is for making the car lower but still an interesting read
I just got a set of aftermarket mx5 / miata shocks to play with for the rear of the brumby
So I've been thinking about it - and I reckon I can flip the shock mounting bracket to drop the rear end a little bit, maybe by an inch... I might experiment with it as I think the look of Ruby's high rear end is growing on me - it kind of looks like Paul's new L's rear end.
Thinking I'll have a gander with the big tyres on to see what it looks like. I need to load it up too just to see what it looks like. Damn work (sometimes). Other than that I'm loving the rebound I get over speed bumps and when passing through driveways.
Much cheaper than a set of rear Kings if you could still get the lifted/upgraded set...
This is what some guy did on USMB....
http://www.ultimatesubaru.org/forum/sho ... ring+perch
Looks like using the Honda civic coil is easier and comes up with similar results.
I'm also looking at getting something better for my car but I wanted to eliminate the C lift used to extend the shock. The Toyota shocks looks great but as said before would have less travel:(
I might just swap to rear civic coil for now as the shocks/springs I have from Alex old wagon have been well used and I think are a bit worn. The front are still great tho:p
The spring from the honda is the front - I went with the civic as I figured that the engine and gearbox are lighter than that of the V6 model that was also out there, there for has a lighter spring rating than the V6 units.guyph_01 wrote:I might just swap to rear civic coil for now as the shocks/springs I have from Alex old wagon have been well used and I think are a bit worn. The front are still great tho:p
Either way I like what I've got. I'll upload some pics from our outing to the Nowa Nowa trestle bridge today... More on that later
So what year and exact model front honda springs you used?
Yeah looks all level and high:) How comfortable is the ride?
