timing retardation and sensors.
hit up Rockauto.com to get part numbers if you don't order through them. Search amazon etc with the part number to shop around for the best deal.
This is how I got my cambelt kit for the EJ at about half price of one over here, including postage! 5 days later it was in my hands and about half an hour after that my engine was running again! Crazy world we live in.
I thought the knock sensor being used to continuously tune the engine was common knowledge?
I bought an AFR sensor from this mob, they were good to deal with and it was half the genuine price
This should suit your car
www.cyberspaceautoparts.com.au/Subaru-Knock-Sensor
$140
$140
i didnt know that haha! learn something new everyday!El_Freddo wrote: I thought the knock sensor being used to continuously tune the engine was common knowledge?
It doesn't "tune" the engine.. it just retards timing when it sensors pre detonation (pinging) to stop the engne melting pistons or damaging big end bearings
But isn't changing the timing a form of tuning?? I also thought that when detonation was detected under load that the fueling increased... But I could be so wrong on this!RSR 555 wrote:It doesn't "tune" the engine.. it just retards timing when it sensors pre detonation (pinging) to stop the engne melting pistons or damaging big end bearings
Well i suppose yes. But i wouldnt call it tuning.El_Freddo wrote:But isn't changing the timing a form of tuning??
The ECU has a timing target for each RPM x Engine Load, based on a software map. (so say for example, at 3000 RPM and 70% load gives 18 deg BTDC) It then takes this target and adds or subtracts the IAT value depending on the intake air temperature (so if 35 deg air gives a subtraction of 2 deg, the timing is now 16 deg BTDC) . This is the ignition timing that is sent to the coils.
If the knock sensor detects pinging, the ECU may subtract 2 deg, then over a period of a few seconds, it slowly returns it to the original value. If knocking reoccurs a few times in a short amount of time, it will wait longer before returning to the original timing value.
If you put 91RON fuel in an engine designed for 98, the ECU will throw a check engine light because the timing it has to reduce it to is below its allowed value.
If the engine was designed for 91RON fuel, it will only ever run enough timing for 91 fuel, even if you run 98 through it. If it did increase the timing on its own, this would be an example of self tuning.
Please note that the above values are examples only
Im sorry Bennie, but the knock sensor has nothing to do with fuelling.I also thought that when detonation was detected under load that the fueling increased... But I could be so wrong on this!
Nah the knock sensor is only used for correcting ignition timing, the oxygen sensor takes care of closed loop fuel control. Open loop fuel control is controlled directly by the fuel map (a combination of RPM x engine load) with slight variations for engine coolant temperature, cold start ect.El_Freddo wrote: I thought the ECU used the knock sensor to also work out the leanest "healthy" fuel ratio that does not cause pinging.
