How to remove R160 Male Stubs
Diff Stubs
A someone else has allready said, you must have a diff with internal circlips. Put the spring pin back in the hole in the stub and use a claw hammer to sharply pry the stub outwards using the pin for leverage against the side of the diff. The Stub will pop out allowing you to then remove the diff centre.
