Thanks Rik, The drive home Showed the the big change as you spoke about. They are nothing alike. The main reason for swapping out the auto to manual is the auto has no 3rd gear and i still have the gearbox that A.P. put together for me , that i was going to put in the M.Y. I dont wish to waste all the good work he put in to it . LOL.riksta wrote:Nice one Rick.
I know you wont know yourself, You have just done what I did allmost six years ago, I went from my old Green MY83 wagon to a gen3 RX Liberty wagon, Its a big change and a hole lot more room and a whole lot nicer to drive.
I allways liked the gen 2 outbacks in blue, and I would think twice about swapping the auto, I did not like mine at first but have changed my mind now, after seeing how far offroad it will go.
Rik.
Rick's Outback
rtcb65
Redneck Rick.
Redneck Rick.
As i said in the first post , the clear coat is peeling . So i have the bonnet back ready to re coat, now just the rest of the peeled panels to rub back it . Also took the auto out ready to put the manual in.
rtcb65
Redneck Rick.
Redneck Rick.
gee you guys are fast workers!
- FROG
I think it would look good in blue with a dark silver/gunmetal grey lower half and garnishes ! PAINT IT BLUE
Hey Bennie,El_Freddo wrote:Sweet! Sounds like you boys are onto something good up there! What an upgrade.
Will there be a change of wardrobe to go with the upgrade in vehicles? Sounds like you won't know yourselves!
No change of wardrobe , we are still Rednecks. Just in new model cars. LOL.
Hey Andy,FROG wrote:I think it would look good in blue with a dark silver/gunmetal grey lower half and garnishes ! PAINT IT BLUE
I like the idea of the blue and gunmetal . Once i get it on the road and drive it around for a while , to get the budget back in line to where i like it. I think i will do the colour change.
rtcb65
Redneck Rick.
Redneck Rick.
blue might look good on the older subis and wrxs, but on an outback i reckon it would look very tacky.rtcb65 wrote:What is your reason for not painting it blue or is blue just not one of the colours you don't like ? The reasons why i was thinking of paint it blue is , 1: blue seems to be our trade mark colour, 2: the colour that is on it is the rusty brown red. I am not that fussed on it.
but hey thats just my opinion
- d_generate
Blue manual only for me
Starting to prep things while waiting for the new rear main seal to turn up. Gear stick and range lever in , but may need little mod done ( make longer mount as stick set out of liberty/impreza ) . Clutch pedal box clean ready. Preping box , speedo sender and mounts. Looking into wiring on box and in car, different. Looks like may have to make up adapter to go between the two. That way box still has own wiring and car has it own wiring , just incase .
rtcb65
Redneck Rick.
Redneck Rick.
once you got all these going you need to update your subie boys logo
looking good, cant wait to see it go extreme
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
I am chasing a diagram of the auto wiring plug ( car side of auto gearbox plug ) so i can adapt it to the gen 1 gearbox wiring plug . Basically make a adapter to join between the to. If anyone can help , i would be great full.
rtcb65
Redneck Rick.
Redneck Rick.
A couple of steps forward. The clutch pedal box is in and all connected. Exhaust is back in. Now to see if the cruise button can stay where it was, with the range lever now there. I was lucky to find a manual gear boot in my home town. One other thing i found , if what i reading and noticing , the speed censor was in the auto box. The gen 1 box doesn't have one in it, so it looks like i have to fit another. The wiring to join the 2 systems up electrically is going to be a job and a half ,Eg : reversing lights, low range, neutral switch and the park and neutral lock out
rtcb65
Redneck Rick.
Redneck Rick.
so you're using a G1 box in a G2 then? I was wondering about the cable clutch. you should be able to get a speed sensor to just plug into the G1 box. I did it the other way, and took the speed sensor off my 98 forrie box and put the G1 cable straight on. I will be watching what you do with the wiring as I have to convert my G1 Lib to manual soon.
- Captain Obvious
you may want to take that foot rest out, it will be a auto one which are bigger the the manual ones and every time you put you foot on the clutch you will hit the rest!!! other than that top work!!!
yep Gen 1 Lib box behind Gen 2 EJ25 outback engine - no problems.Point wrote:so you're using a G1 box in a G2 then? I was wondering about the cable clutch. you should be able to get a speed sensor to just plug into the G1 box. I did it the other way, and took the speed sensor off my 98 forrie box and put the G1 cable straight on. I will be watching what you do with the wiring as I have to convert my G1 Lib to manual soon.
That box did have cable sensor, pulled it out and you can install electric one - no problems.
Hey AP ,AlpineRaven wrote:yep Gen 1 Lib box behind Gen 2 EJ25 outback engine - no problems.
Got the box wiring sorted out today. What a nightmare. Steve , myself , Ross and pages upon pages of wiring diagrams. But it done. Now to make up a new plenum mount , exhaust bracket , change diff ratio and find a second/tail part of a tail shaft that is 900 mm long and it should be close to being ready for rego. Fingers crossed.
rtcb65
Redneck Rick.
Redneck Rick.
- d_generate
You can trim the footrest down easy enough, worked on mine.
Solved the foot rest prob. I remembered i had on out of a forester , So i put it in. Steve worked his magic and made up a set of plenum chamber mounts to replace the auto mount ones.
rtcb65
Redneck Rick.
Redneck Rick.
