Heres what we have for a roof line on our Legacys, looks like the uk version is different[ATTACH]2311[/ATTACH]rtcb65 wrote:Hey Mark,
No mate, it isn't a Tourer. Just a Gx liberty. Or in your part of the world, A Legacy. LOL.
Rosco's liberty wagon
- T'subaru
- 250px-USDM_side-1-.jpg (9.05 KiB) Viewed 26940 times
T'subaru wrote:Thats a good looking wagon, and I like the roof line, is that a touring wagon?
Cheers, mark
Yeah Mark.. your Legacy low roofs were never available here in Aus so the high roof model (Touring Wagon JDM & USDM) are just Liberty's to usT'subaru wrote:Heres what we have for a roof line on our Legacys, looks like the uk version is different[ATTACH]2311[/ATTACH]
- Captain Obvious
you can run about a 28'' tyre but you need gen2 outback struts to do this!! also it is best if you are going to run that bigger rubber to convert to 4.11 ratio as 3.9 is i little tall. i am running 215/65/16 on mine which is 27''. search on here, vincentvega has covered it a few times.guyph_01 wrote:Hey mate,
What size tyres are you using? We lifted a liberty by two inch and trying to get the biggest tyres to fit.
Thx
bryan
p.s looking good rosco!!
If you want to get the rear wheels to sit back in the centre of the wheel arch
you can either change the lift kit blocks on the trailing arm mounts from two to three inch blocks, or fit some Gen1 Outback trailing arm mounts instead, the part numbers for the outback mounts are
20520AC030 --- RH
20520AC040 --- LH
Off the top of my head I think they are about a 100 bucks for the pair.
Cheers Grant
20520AC030 --- RH
20520AC040 --- LH
Cheers Grant
That pics looks a bit wonky :SSubaman wrote:If you want to get the rear wheels to sit back in the centre of the wheel arch
20520AC030 --- RH
20520AC040 --- LH
Cheers Grant
Thanks Grant,Subaman wrote:If you want to get the rear wheels to sit back in the centre of the wheel arch
20520AC030 --- RH
20520AC040 --- LH
Cheers Grant
That is what we are looking into. The outback trailing arm mounts. Thanks for the info though.
It does, doesn't it, that is what happens when you just do bolts up. Then get it back on its boots, and take a pic before looking and adjusting. LOLRSR 555 wrote:That pics looks a bit wonky :S
rtcb65
Redneck Rick.
Redneck Rick.
I hope he puts the other 2 wheel nuts on toortcb65 wrote:It does, doesn't it, that is what happens when you just do bolts up. Then get it back on its boots, and take a pic before looking and adjusting. LOL
Yep, All wheel nuts are on it now.RSR 555 wrote:I hope he puts the other 2 wheel nuts on too
rtcb65
Redneck Rick.
Redneck Rick.
- Captain Obvious
i like the offset of those wheels!!!
If i remember right, they are a 38 off set.Captain Obvious wrote:i like the offset of those wheels!!!
rtcb65
Redneck Rick.
Redneck Rick.
- ScubyRoo
I have a set of said trailing arm mounts - $75 inc postage....
I now have no need for them as my lib is no longer lifted...
Owen.
Owen.
Hey Mate, If you are willing to hang on to them for a little longer. He is very interested in them . His Mrs car just dropped reverse in the auto, so it needs to be fixed first.ScubyRoo wrote:I have a set of said trailing arm mounts - $75 inc postage....
Owen.
rtcb65
Redneck Rick.
Redneck Rick.
- ScubyRoo
No worries, no one else has ask for them so just shoot me a PM when the time comes...
Popped a seal in the auto , so out comes the box and replace the seal. That makes it 2 auto gear box's out of 3 auto cars that have had to have work done on them. It is a good learning experience . Learn learn learn..
rtcb65
Redneck Rick.
Redneck Rick.
- vincentvega
The one the torque converter goes through. Or known as front gearbox seal.vincentvega wrote:which seal failed?
rtcb65
Redneck Rick.
Redneck Rick.
- vincentvega
Yeah, we are finding out. It has happened to all 3 auto liberty's so far. just got to two of them so far. At least once they done, we don't have to worry about them for awhile. Also it good practice.vincentvega wrote:the old back to back seals. so your front diff filled up with trans fluid? pretty common occurance
rtcb65
Redneck Rick.
Redneck Rick.
