Subaru MY06 Outback - Aux Input Question
Get wild & funky with your Mobile disco ...
Diesel OB
Post by Diesel OB » Tue Apr 06, 2010 7:35 pm
Chris_Rogers wrote:ok so you have the screen with navi? if not the radio is a panasonic and to my knowledge locally (yet to look in japan) nothing available for it.
Hi Chris,
Thanks for the reply, Just the base model no screen....looks like I will need to watch this space.
Thanks Phil
Chris_Rogers
Post by Chris_Rogers » Wed Apr 21, 2010 10:03 pm
my two girls I deal with in japan say no..
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
Diesel OB
Post by Diesel OB » Thu Apr 22, 2010 10:34 pm
Thanks for looking anyway!!!
Barry1956
Post by Barry1956 » Fri May 28, 2010 11:12 pm
Chris @ #22,
Any idea if any of these can be had in Aus (or sourced from Japan) and if so, the price?
Barry
Chris_Rogers
Post by Chris_Rogers » Sat May 29, 2010 4:10 pm
yep I can get the one I put up earlier without issue. could couple it with an ipod lead as well if needed.
Audio Express
tmiller1079
Post by tmiller1079 » Fri Jun 11, 2010 9:02 pm
Does anyone know if the Subaru part is backwards compatible for an '04 Gen 4 Outback? Or do they make an 'aux' that is?
Chris_Rogers
Post by Chris_Rogers » Sat Jun 12, 2010 7:51 am
nope. the kenwood units of that generation have a phone input only.
Audio Express
Tuckerman
Post by Tuckerman » Sun Jun 27, 2010 7:56 pm
hey guys, I have a MY10 XT Forry and was wondering if the "Media Hub" component fits my vehicle ? I have the full Sat Nav system (believe it is a Kenwood unit built for Subaru). I have the aux inputs int he centre console but a USB or ipod/iphone input would be much more useful :)
Thanks
Tom
SVXdc
Post by SVXdc » Mon Nov 01, 2010 1:28 pm
Here are a few pictures you might find helpful regarding the aux jack:
GX-204KH radio:
Front:
[INDENT][ATTACH]2359[/ATTACH][/INDENT]
Rear:
[INDENT][ATTACH]2360[/ATTACH][/INDENT]
close-up:
[INDENT][ATTACH]2361[/ATTACH][/INDENT]
Connectors on rear (from left to right, as seen in picture):
1) Fly-lead with Subaru proprietary antenna socket (w/ dual antenna leads)
2) 14-pin socket for power/speaker harness. Pin-out table
3) 20-pin socket for external CD changer, iPod interface (and in North America, also Sirius/XM satellite radio tuner modules)
4) 8-pin socket for aux input, steering wheel controls, night illumination dimness cancellation. Pin-out (see section '2007-up Legacy/Liberty/Outback' in post 10 of that thread)
Aux pod exploded view:
[INDENT][ATTACH]2362[/ATTACH][/INDENT]
back of PC board:
[INDENT][ATTACH]2363[/ATTACH][/INDENT]
Pin-out of 6-pin plug on OEM aux harness (plugs into bottom of aux pod)
(in the above picture, pin 1 is the leftmost pad in the row just above the two screws)
1 Right audio (3.5mm plug "ring")
2 Audio Ground (3.5mm plug "sleeve")
3 Left audio (3.5mm plug "tip")
4 Audio Ground (tied to pin 2)
5 Enable switch -- common
6 Enable switch -- normally-open contact
The enable switch is a separate piece "docked" to the tip end of the 3.5mm jack. The tip of the plug pushes the switch. The switch tells the radio to enable the aux button (for details, see link to 8-pin socket pin-out, above).
When no 3.5mm plug is present, the jack itself also shorts the left and right audio signal leads to audio ground (to prevent unwanted noise from getting into the radio). Keep this in mind if you're thinking of wiring a second audio source to the aux input.
(and thanks, thatsgoodsquishy, for posting the scans of the installation instructions!)
ADDED: Great walk-through with pictures: DIY: AUX-IN after mount + Center console removal -Legacy 2008
(In my post #17 there, I attached the PDF for Subaru's installation instructions for the OEM H6210AG000 aux kit).
Legacy aux pod PC board.jpg (68.42 KiB) Viewed 8499 times
Legacy aux pod exploded.jpg (39.08 KiB) Viewed 8501 times
GX-204KH rear 2.jpg (10.3 KiB) Viewed 8499 times
GX-204KH rear 1.jpg (16.9 KiB) Viewed 8500 times
GX-204KH front 2.jpg (17.67 KiB) Viewed 8500 times
1996 SVX L AWD Laguna Blue Pearl
Useful Subaru pin-outs and other info
SUBYDAZZ
MY06 or MY07
Post by SUBYDAZZ » Thu Nov 10, 2011 7:09 am
OzWolf wrote:...I have a MY06 2.5i Outback (base model, so no sat nav, etc.). It has a 6-disc stacker factory unit. On the front source selector, there is an AUX option (which leads me to believe it is capable of achieving what I want)....
Are you sure it's a MY06 or is it a late 2006 model MY07? Because I'm almost certain MY06 never had the head unit of which you speak. If it's that unit you will be able to fit the AUX input kit.
SUBYDAZZ
Chris_Rogers
Post by Chris_Rogers » Thu Nov 10, 2011 7:43 am
late 2006 or 2007. early 2006 had a silver panel and a different radio. I get request for them a fair bit. I keep a fly lead instock for these units for this very reason
Audio Express
da5101
What did you end up doing?
Post by da5101 » Thu Mar 22, 2012 6:58 pm
Hi, im wondering what you decided on doing did you get the parrot or a aftermarket head unit? Am looking for a GX-204KH head unit as mine decided to give up the ghost and am looking to buy one again and installed it back into my car.
Chris_Rogers
Post by Chris_Rogers » Mon Mar 26, 2012 11:55 am
parrot MKI9100 would be a better idea. the early 'silver' units do not have any sort of audio input on them . the later one does but they are not interchangeable.
Audio Express
da5101
Post by da5101 » Tue Mar 27, 2012 10:19 am
ill have one i would like that how do i purchase
Return to “Sound / Entertainment Systems”
