Solid axel conversion for brumby
Post by Gannon » Tue Jan 26, 2010 10:09 am
+1 for the rubber flap idea
My 84 4WD wagon had little flaps than hung down in front of the CV boots.
This is a scan from the "Four Wheel Driving with Subaru" handbook
Im sure it wouldnt take much to knock up something like this
It is gonna be 1000 times cheaper than a full live rear axle setup.
fredsub
Post by fredsub » Tue Jan 26, 2010 10:38 am
i don't think live-axles are the premier solution any more....
as evidenced by the likes of many 4wd makes, and hummer, trucks - kamatz, etc
besides WTF is the idea of a subaru to be a rock hopper ?
i recall a few years ago seeing the Subaru rally team use rubber covers suspended below the inner cvs. they were also using something for the outers i think, but can't recall enough, and can't find the pics.
Post by D3V1L » Tue Jan 26, 2010 11:00 am
hey brumby runner, great pics of the live axle soobs
i was considering doing the same thing to a brumby a while back. as a rock crawler..
but subaru not haveing a suitable chassis to modify, especially for a triangulated 4link such as the one pictured, and i was concerned it would just damage the body too much. but 4link and hilux diffs as hes got i reckon is the way foreward :) not biased or anything
instead of doing a brumby for myself., i ended up doing 4link and hilux diffs to a dihatsu scat for my rock crawler.
and im gonna leave my brumby project for the road :P
dave
mcbrat
Post by mcbrat » Mon Mar 22, 2010 2:14 am
Post by RSR 555 » Mon Mar 22, 2010 1:25 pm
mcbrat wrote:detailed pics here....
http://www.indysworld.com/vehicles/1982 ... dbrat.html
:shock::shock::shock::shock: AWESOME !!
mud_king91
Post by mud_king91 » Thu Sep 22, 2011 10:40 pm
well sorry to upset you all but i intend on live axle coil springing a sherpa/fiori offroad only of course
Post by TOONGA » Fri Sep 23, 2011 9:04 am
mud_king91 wrote:well sorry to upset you all but i intend on live axle coil springing a sherpa/fiori offroad only of course
ok sounds interesting... will need pictures and medication to suit desired project :)
mud_king91
Post by mud_king91 » Fri Sep 23, 2011 9:15 am
TOONGA wrote:ok sounds interesting... will need pictures and medication to suit desired project :)
BAHAHAHAHA im starting jan 1st just to gauge exactly how long it takes yes you will all get pics and medication ? you mean steroids for the car right ?
Post by Alex » Fri Sep 23, 2011 9:24 am
i'll believe it when i see it.
once you start thinking about it 99.9% of these ideas never take off.
if you do it, good job.
spike
Post by spike » Tue Sep 27, 2011 7:34 pm
Alex wrote:i'll believe it when i see it.
it sounds like its going to be more of tube chassis with a fiori body, not really hard when you think about it. consider the number of them that are out there with different bodies?
mud_king91
Post by mud_king91 » Tue Sep 27, 2011 8:01 pm
spike wrote:it sounds like its going to be more of tube chassis with a fiori body, not really hard when you think about it. consider the number of them that are out there with different bodies?
i know and no matter which way i work it i have to make a tube chassis to hold the engine and box i havnt even considered the springs yet
spike
Post by spike » Fri Sep 30, 2011 7:19 pm
get onto the hard core rock crawling sites and see how they do it. most are full tube chassis with a body dropped on top.
from the little things ive picked up GU axles front and rear, 4 link set up, due to the problem of having no engine room youd want to run a EJ turbo or somthing
mud_king91
Post by mud_king91 » Fri Sep 30, 2011 7:22 pm
exactly and due to that i cant justify doing it sure if i were into comp spec then it would be worht doing problem is doing all that work and its not worth much... might put it off till i find a use for a comp truck... and have a vehicle that,ll tow it
spike
Post by spike » Sat Oct 01, 2011 10:35 am
yeahs and getting a car past regency for on the road is not gonna happen like that. But its a good plan hahha
mud_king91
Post by mud_king91 » Sat Oct 01, 2011 11:01 am
iv heard the hilux/landcruiser chassis with a different body generally works tho... maybe ill give that a go later in life
spike
Post by spike » Sat Oct 01, 2011 1:26 pm
the hilux is somwhat common, brumby's and MY have been done. id look into somthing like a vitara or sieera and drop the body on top
