List MY differences here ...
heres one i did a couple of years ago that turned a lot of heads. 1980 leone sedan honestly to my knowledge only ever came out two wheel drive, (feel free to corect me if i"m wrong) three very simple mods to do a 4WD convertion. first is the rear cross member holding the fuel tank in. move it toward the rear of the car about 4 inchs, allowing the 4wd tank to fit. two, make or take from a donor car the tunnel mount for the 4wd selector, and three take all the running gear out of that donor car and bolt it straight in. these cars are so interchangable its not funny and as far as most poeple are concerned most or all subys were 4wd so no-one will ever be the wiser. and they seem to be a lot more fun than the wagons.
IF YOU CANT MAKE IT IN 1st, BACK UP AND HIT IT IN 3rd.[SIGPIC][/SIGPIC]
82 I think was the last year for non-vented discs...
- phillatdarwin
- TheInterceptor
you can fit a left mirror to a <1983 model coupe, the nut and flange is welded to the inside of the skin, even if the door never had a mirror (can also use '83> square type)
It might be scrap metal with wheels, but its MY scrap metal with wheels and I love her dearly!
(MY82 Leone GLF Coupe)
bent, twisted, rusted out, electrical faults and useless rubber seals, still the only car i got that starts every time i try. no matter the weather, or how long its been sitting. or whatever... unconditional love.
Having just fitted an L Series radius rod with its rubber bushes to my Brumby and so initial differences obvious - thought worth a mention in here. Brumby was ~17mm dia, L Series ~ 18mm dia. The dished washer welded to rod faces opposite direction between the models. Checked with Mr Pedder who has notation that one set of L Series rod bushes of the L Series can be used on MY, the second listing they have is not recommended due to slop. I retained L rubbers in the fit to Brumby. Now need to fit same to other side.
Later edit: found there is about a 5mm difference between what counts, the MY is longer. Still L worked OK for a temporary spare
- Silverbullet
Yeah I agreeSilverbullet wrote:I think that's only from the driver's side, if you unlock passenger side it's clockwise, in other words from either side you're turning the key towards the rear.
Not a difference, but a same ....little black plastic pollution control device on 89 -92 Brumby with four hoses + one outlet blanked off, sits near oil filler tube is same as the one on early L carby models at least, and sits opposite end of air box to the Brumby. Swap the blank cap from one side to the other - BINGO
Front disc brake Rotors
2 x solid and 1 vented Rotors in MYs
Protex catalogue has
solid as DR342 for "Brumby A - 69" 78-89,
solid as DR340 "Leone 1600 & 1800 4WD" 80-84
vented as
"brumby AU" 85-93 AND "Leone 1600,1800" 84-85
solids
"thick" solid
DBA part DBA342 229mm
Protex DR342 229mm
thickness is 12.5mm, min thickness 10mm,
"thin" solid
Protex DR340 229mm
thickness is 10mm, min thickness 8.5,
vented
DBA part DBA640 230mm
Protex part DR640 230mm
Thickness is 18mm, min thickness 15.5
vented as
solids
"thick" solid
Protex DR342 229mm
"thin" solid
Protex DR340 229mm
vented
