Rebuilding an ea82
jims
Post by jims » Fri Apr 05, 2013 9:20 pm
Anyway to check oil pressure? Could a worn pump be causing lifters to starve?
Post by steptoe » Fri Apr 05, 2013 9:57 pm
is it a lifter or is it a gudgeon pin nicking on the side of the bore ?
There! I said it!
Check oil pressure with a gauge in the oil pressure switch hole - either a diagnostic gauge or an after market dash gauge - capilary or electric ....
You will be better off puling this baby down before something breaks ....
Post by TOONGA » Sat Apr 06, 2013 7:57 am
You sure it is lifter noise and not a a gudgeon rattling against the bore and piston.
If you found a gudgeon clip in the oil, it is time to get the engine out as Gary and Jonno have both said.
Brumby Kid
Post by Brumby Kid » Sat Apr 06, 2013 2:38 pm
steptoe wrote:is it a lifter or is it a gudgeon pin nicking on the side of the bore ?
There! I said it!
Brave man saying that steptoe but i think it is likely.
These would be Hydrolic lifters wouldn't they? Other wise i would have said your valve clearances need doing again.
Engine out for peace of mind and safety
Cheers Cam
Dads Car: 02 Impreza WRX STi
jims
Post by jims » Sat Apr 06, 2013 9:19 pm
Yeah thanks guys
Brumby Kid
Post by Brumby Kid » Sat Apr 06, 2013 9:38 pm
How does a C clip fall out?
Bloody hard to get in and out
Doesn't seem like the sort of thing that could just "fall" out
Never went in properly?
Cheers Cam
Subydoug
Post by Subydoug » Sat Apr 06, 2013 9:51 pm
Not sure how it is on the ea82, but it could possibly drop out of the cylinder and into the sump at BDC. Id deffinately be pulling out the plugs at the least to see if the gudgeon clips are there. At the very least it can tell you which piston it is so you only remove that head. Bugger :(.
Yes it usually will only come out if incorrectly installed or damaged during install. They are a prick to put in thru the holes in the cylinders.
Doug
Post by steptoe » Sun Apr 07, 2013 7:09 am
got me stuffed how the middle pistons are done on the variety of H6s starting with ER27 in the XT6 Vortex
Post by RSR 555 » Thu Apr 11, 2013 11:49 pm
James, sounds like the clip didn't go back in correctly. They are painful to get right but looks like the engine needs to come out again.
Jonno.. Long nose pliers
Post by El_Freddo » Fri Apr 12, 2013 7:52 pm
jims wrote:Okay guys, new problem. Lifter noise.
Initially the car ran quiet. It then developed a loud lifter tick. I ran a bottle of that lifter free stuff through and it stopped all together. Now it's come back and after an oil change and another bottle of lifter free it won't go away.
Well, it is an EA82. I still swear by my fix I use - but Jonno and others don't always agree... EJ it :twisted:
jims wrote:I installed brand new lifters when I did the rebuild as well as new oil pump seal and timing belts. Could I have an oil pressure problem? The oil light goes out but it's the only thing I can think of.
thoughts?
Hook up an oil pressure gauge and you'll be able to tell what's going on by that. I can tell when my engine is overheating by looking at the oil pressure...
The other thing to check out is the cam box. From memory there's a little ball and spring setup in there that must regulate the oil pressure to the lifters. Make sure this is all cleaned out and the spring isn't clagged up with crud. A new spring might not be a bad idea either.
Re: The C clip:
littlewhiteute wrote:You're in a lot of trouble.
Could be any one of 8.
Sorry to say, engine out.
Agreed. If you're lucky it'll be one on the access hole side. If your hanging out with Murphy, it'll be on the opposite side to the access hole :(
Brumby Kid wrote:How does a C clip fall out?
Probably never went in properly - which makes me think that it is the one on the access hole side of the piston. When we rebuild the engines these clips that are on the opposite side of the access hole go in before the piston is installed in the engine - saves trying to put an extra clip on through a tiny access hole...
Best of luck with it - Let us know how you get a long with it. Hopefully you've dodged a VERY large bullet!
I'd be removing the access holes and seeing if it's one of the close ones before going to the extremes of pulling pistons out!
Post by steptoe » Fri Apr 12, 2013 8:32 pm
If it is an outer you'd be lucky if it was one of the front ones and not behind the water pump.....no engine removal !
