Fitting an EJ Motor into an MY or L Series Subaru
Post by TOONGA » Thu Apr 14, 2011 8:24 pm
A search on google got me this
showthread.php?p=138712
which got me this
http://www.suberdave.com/USMB/95_Impreza_18l_wiring.pdf
apparently they use the same wiring ???
I don't think so
still looking
L series porn
http://wordpress.suberdave.com/
found these as well
http://www.main.experiencetherave.com/s ... nouts1.jpg
http://www.main.experiencetherave.com/s ... nouts2.jpg
http://www.main.experiencetherave.com/s ... 6specs.jpg
language is Spanish
Post by Gannon » Thu Apr 14, 2011 8:42 pm
GOD wrote: EJ16s and EJ18s don't have a cam sensor or a knock sensor. Don't think they had any ECU control of the EGR gear either.
Actually, i think this may only apply to single point fuel injected models.
BaronVonChickenPants
Post by BaronVonChickenPants » Thu Apr 14, 2011 9:21 pm
Sorry, meant to post this earlier but got distracted by something shiny (*cough* Gran Turismo 5 *cough*)
This is everything I have from when I was doing my EJ18 conversion, I was told the EJ16 was the same also.
FSM Scans
I have most of them in high resolution if you need it.
Jordan.
Post by steptoe » Thu Apr 14, 2011 10:48 pm
Jordan ! You've moved again?
Thanks guys I shall have a look in time at the links.Hey even my 86 4GLTA ECU 3 plugger has some EGR control, well it is suppose to not operate below a certain temp or work above a certain speed. It does not have these limits - works all the time.
The donk came out of a crashed Impreza 1996 under yella oil cap - got the loom and ECU expertly removed by Damo666 and donated to a good home :)
GOD
Post by GOD » Fri Apr 15, 2011 1:40 am
Suparoo wrote:Actually, i think this may only apply to single point fuel injected models.
Nope, all (four?) the Australian MPFI EJ16/18s I've looked at have been like this.
B00sting
Post by B00sting » Tue Jan 31, 2012 7:15 pm
Anyone know if you can lift a brumby (93) to avoid chassis rail modification when dropping a DOHC ej25 in?
If so how much is needed?
-97 Landcruiser :D
yarney
Post by yarney » Fri Feb 10, 2012 4:28 pm
B00sting wrote:Anyone know if you can lift a brumby (93) to avoid chassis rail modification when dropping a DOHC ej25 in?
Do you really need a DOHC motor? an EJ22 has got plenty of power and a hell of a lot cheaper to buy or even a EJ20.
Have a look at 92 brumby he has only got a SOHC EJ20 in it and it goes well even with 30" tyres.
Jan
B00sting
Post by B00sting » Fri Feb 10, 2012 7:53 pm
yarney wrote:Do you really need a DOHC motor? an EJ22 has got plenty of power and a hell of a lot cheaper to buy or even a EJ20.
Jan
Actually I'd just like an answer to my question if possible :)
Does it matter what I want? It doesn't effect anyone else....
Cheers.
-97 Landcruiser :D
Post by AndrewT » Mon Feb 13, 2012 4:43 pm
Tim (the opening poster of this thread) had a 4" lift in his MY wagon at one point, still needed the rail mod to fit the DOHC motor.
It's only a minor mod, not structural, easy to do and if done well - not obvious to look at. If your heart is set on a DOHC motor, just do it.
90brumby
Post by 90brumby » Mon Feb 13, 2012 9:13 pm
i reckon with the 6inch lift i had in my car the DOHC would have fit but if you want dohc just do the rail mod like andrew said
tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
B00sting
Post by B00sting » Sun Mar 04, 2012 7:18 pm
Is it any easier to fit the early ej25s (e.g outback 99) versus the 2006-2010 forester engines?
I can get a 2010 motor for a good price is all.
-97 Landcruiser :D
Scheffer1986
fitting a ej25 to a 82 my
Post by Scheffer1986 » Fri Jun 22, 2012 8:30 am
Has anyone fit a ej253 sohco into a brumby/my wagon ?
ajcmbrown
Ideal donor car for EJ conversion?
Post by ajcmbrown » Thu Jul 11, 2013 10:08 am
While pondering an EJ conversion, it dawned on me that there must be an "ideal" donor car for the job, not what is possible, but for example, what would be the best use of the parts available from just one car without cutting chassis rails etc, Forester two litre EJ with manual D/R g/box, so that I can use drive shafts, diff assy, wheels, brakes, steering column etc.
Is this feasible in just one model?
Am I being overly optimistic in thinking that I could do a drive-line update without having to make major modifications like fitting an EJ25 for example?
My old Brumby that I have on the farm (2 actually) which I am contemplating putting on the road would be a lot more enjoyable if it were for example a EJ20-EJ22 N/A manual D/R gearbox with matching rear diff, drive shafts, upgraded brakes, front suspension?, etc.
What model would give me the best "bang for my buck" if I were to buy just one donor car?
I would think that there would be others who would find this interesting before deciding on an engine/gearbox combo that could need extra parts to be sourced from different models.
Post by El_Freddo » Sat Jul 13, 2013 3:59 pm
I'm sure it's been done. Same as an EJ22 SOHC conversion pretty much.
ozbrumby
Post by ozbrumby » Sat Mar 22, 2014 9:24 am
My 91 Brumby has a SOHC 2.5L in it with the AWD setup
Scheffer1986 wrote:Has anyone fit a ej253 sohco into a brumby/my wagon ?
Alpinebarry
Hi guys
Post by Alpinebarry » Mon Nov 17, 2014 8:14 pm
New to site and subaru world as such. Just starting my own El22 swap into my ea82 L series. Lookin for all the help I can get
Post by TOONGA » Mon Nov 17, 2014 9:29 pm
El freddos thread about his "L" series would be a good start
showthread.php?t=11733
my thread if you want to go carby and dizzy
showthread.php?t=15851
this PDF will help as well
downloads.php?do=file&id=134
Good luck with it
Post by El_Freddo » Mon Nov 17, 2014 10:40 pm
Barry,
I found that post of AndrewT's of how to make your own adaptor plate here
Also, this might be worth a read for you too.
I'll update the last link as I've done some new things that are worth knowing about in my opinion.
Willy Fisterbottom
Re: Fitting an EJ Motor into an MY or L Series Subaru
Post by Willy Fisterbottom » Tue Sep 18, 2018 6:31 pm
*Engine
