My Touring Wagon EJ25 build, Part 2
Post by guyph_01 » Mon Sep 19, 2011 12:16 pm
SO little update, Nothing has been happening mechanically so i tidied up the cargo area. I got a new second hand MP3 CD stater to replace the old normal one, Tucked all the Amp and accessories electrical wires neatly, Also had some paint left so why not, lol
Bottom pic has two racing yellow strips on the the red bar, will try and get a better pic this avo when the sun changes:)
Still waiting on the new second hand deck to arrive from ebay:p
made24x4
Post by made24x4 » Wed Sep 21, 2011 7:32 pm
hi im cuttently putting an ej 20 into my L with the awd 4.11 duel range forester diff and box just wondering if some one knows how to get the hydrolic ej clutch to work in the L do i need to use a ej pedel box
Post by guyph_01 » Wed Sep 21, 2011 9:46 pm
First, Start your own thread., so people can reply there.
Second, i don't think its too hard, you just have to drill a whole in the firewall for the hydrolic clutch. Once you get the parts you will be able to see and make it work.
Pm AndrewT and ask him, he has done it twice in a L coupe and a wagon.
Post by guyph_01 » Thu Sep 22, 2011 12:19 am
:D lol here is what it looks like. Man i'm so bored and really need to get this car finished before i paint it pink or something. Thank god there's the vortex:)
Post by RSR 555 » Sun Sep 25, 2011 11:31 pm
guyph_01 wrote:Image
Spot the differences :???:
Post by guyph_01 » Sun Sep 25, 2011 11:38 pm
No difference really, Only first pic had full sun over it and the bar did come up as red but more yellow. Second pic was to show the true color...
Post by RSR 555 » Mon Sep 26, 2011 12:10 am
guyph_01 wrote:No difference really, Only first pic had full sun over it and the bar did come up as red but more yellow. Second pic was to show the true color...
Well spotted.. you win todays prize :mrgreen:
Personnally, I would have just updated the first pic :)
Post by guyph_01 » Mon Sep 26, 2011 12:38 am
SO sry Paul, My bad, next time i won't make the same mistake:p
Post by RSR 555 » Mon Sep 26, 2011 1:26 am
guyph_01 wrote:SO sry Paul, My bad, next time i won't make the same mistake:p
Promises.. promises.. we'll see :mrgreen:
Really was just trying to make sure there was a couple more McD special shots in your thread
Post by guyph_01 » Mon Sep 26, 2011 9:38 am
Yes i see now, with you adding two more copies in your post:)
Wagonman
Post by Wagonman » Mon Sep 26, 2011 5:51 pm
Settle down ladies haha...
Looking great guy.. oh and your car is too ;) (no homo)
Post by Alex » Mon Sep 26, 2011 6:35 pm
does this thread make anyone else want a big mac?
mud_king91
Post by mud_king91 » Mon Sep 26, 2011 6:46 pm
nah i got free maccas yesterday
Post by guyph_01 » Mon Sep 26, 2011 9:11 pm
Ok, so the reason for all this nonsense and time wasted on painting etc is that i found a coolant leak on the engine a few weeks ago.
First i though it was coming from the water pump, running along the bottom of the engine and dripping at the back of the head. But it turns out that the water pump isn't leaking.
It seems the leak is coming from the head. Very very weird but yeah coolant is dripping from the back of the head:(
So now i need to take the engine out and get the heads gaskets replaced:(
With my lack of knowledge, all this trouble now falls back onto Paul, poor Paul...
So we are now trying to figure out what are the proper replacement parts we need for my Russian engine. And yes, Since it is now a must i'll get the water pump, pulleys and T-belt replaced. Might as well.
Only down side, its gonna be a while till i finally drive her and i'll be even more broke :cry:
coupe
Post by coupe » Mon Sep 26, 2011 10:18 pm
Bugger Guy that sucks.
I had the same leak in my auto vortex when i got her in 99, i put some Cargo metalic sealup in her and i still havent had to do the gasket. Im going to replace the gasket finally.
I hope it only the gasket mate and its reasonably painless.
Use The Fork Luke
Post by El_Freddo » Mon Sep 26, 2011 10:27 pm
coupe wrote: I hope it only the gasket mate and its reasonably painless.
My thoughts too. Just when everything seemed to be going so well mate!
Bugger.
taza
Post by taza » Mon Sep 26, 2011 10:42 pm
I have to ask are the head gaskets a big and/or expensive job to do? I have coolant stains on the bottom of my engine block too but not that bad. Had a pressure test done on the radiator and it was fine a few months ago.
Post by El_Freddo » Mon Sep 26, 2011 10:57 pm
taza wrote:I have to ask are the head gaskets a big and/or expensive job to do? I have coolant stains on the bottom of my engine block too but not that bad. Had a pressure test done on the radiator and it was fine a few months ago.
Tarren, probably best to start your own thread about it in the workshop part of the forum - we don't want to piss guyph off like Paul did with his bit of fun above...
But in short it is generally considered a big job and it can be expensive depending on how far you go with things but you would want to do the water pump and a timing kit while you're in there. If you go all new seals for everything else that adds to the cost. Do it yourself/with some mates and it might cost you a few beers and a bbq ;)
Post by TOONGA » Tue Sep 27, 2011 9:06 am
Im hoping Guy that you have checked the metal heater pipes on the engine for leaks, before you go pulling the engine out. that leak seems to run from the top of the left head down the back of the block.
Post by guyph_01 » Tue Sep 27, 2011 11:36 am
El_Freddo wrote:Tarren, probably best to start your own thread about it in the workshop part of the forum - we don't want to piss guyph off like Paul did with his bit of fun above...
Lol good one, I'm not that bad:)
TOONGA wrote:Im hoping Guy that you have checked the metal heater pipes on the engine for leaks, before you go pulling the engine out. that leak seems to run from the top of the left head down the back of the block.
Yeah well it checked it a few times and Paul came and checked it too and gave the final verdict
Return to “Guyph”
