Dann's 92 Subaru L Series Build
hose to hose, Just connect this to the hose that goes in the body and get rid of everything else.
Works fine for me:)
Works fine for me:)
The tank is the vacuum canister, good to keep as this is how your climate controls worked from factory.Dann wrote:And just wondering what is this and what is it for, do I need it??
WTF by Dann_Evans, on Flickr
The wires and relays below are for the AC - the one with the vacuum hose can be closed off and looped around on itself as the EJ won't need it once/if you get the AC connected and gassed up. I've not got my AC connected but I would like to have it, just money holds me back.
True True, yeah i'll have a look,El_Freddo wrote:The tank is the vacuum canister, good to keep as this is how your climate controls worked from factory.
Another question what is this pipe for?? Do I need it?? if so where do I attach it??vvvv
IMG_3464 by Dann_Evans, on Flickr
The update for today is just finishing off the little bits and bobs, like connecting all the hoses to the engine, heater, fuel, accelerator, etc, put the radiator in, lined up the power steering knuckle to get welded tomoz, cleaned up some wiring, heres a pic of the progress so far.
All thats got to be done now is, bend and weld the liberty exhuast on, fit the steering knuckle, and then the long wiat til the weekend for Dave(subarino) to work his magic on my wiring, then fire in the hall :P
IMG_3466 by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
oh ok... Wait you guys have brakes??Wagonman wrote:They went with out that back in the old days.. so she'll be rightNah bro thats your brake booster vacuum connection. you defs wanna be putting that on. I found the standard ea brake booster vac hose reached just fine.. the ej one is in a very similar position.
haha yeah I'll have a fiddle around tomoz with that.
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
- d_generate
Going great mate, can't wait till we all get out there again, you'll be flying up that triple track hill at Two Rocks.
Tom those tracks are flat now the last time I when lol,d_generate wrote:Going great mate, can't wait till we all get out there again, you'll be flying up that triple track hill at Two Rocks.
Yes I'll defiantly be connecting up my aircon, summer gets quiet hot,El_Freddo wrote:Looking good mate! Will you be connecting up your AC? It's something I want to do, but I've got a few things to do to Ruby Scoo before hand, plus I've not got the money to have the pipes made up and have the system gassed.
Thanks mate down to the last bits now and finding little annoying things that are setting me back... hope I can get everything done before sunday so dave can wire it upnachaluva wrote:Looking good. Hope all the fiddly bits go well...
cheers, and yeah does look pretty close in the pic, but theres about an inch gap by the pulley shrouds and bout slightly more than a 2 inch gap else where.Alex wrote:very neat mate good work.
ps i like how close the pulley shrouds are to the radiator!
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
alright another little question can I run the car without the aircon hoses attached, or do I need them on?? cause it will be alittle bit before I can sort out the hose adapter,
Also can someone please post up a pic of where and what the hose looks like for the brake booster cause i'm confused, Thanks
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
- TOONGA
Dann this is on my brumby, but it is in the exact same spot on the liberty and "L" series motor. just make sure the one way valve is hooked up the right way.
In the picture it is the hose that runs above the brake reservoir across to the manifold near the two bolt holes.
as for the aircon you don't need it hooked up to run the car mine isn't in Jetcar. (eventually it will be) just make sure all the hose ends are sealed and taped securely.
thanks jules, so just confirming the hose is there for what?? is it just a vaccum hose for the booster or something else,
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
hahah yeah I just had another look and found it under the engine cover, and yes I took the hose off the ea82 but it's cracked so i'll pop off to the shops tomorrow and get it along with lots of other little last minute things.
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
don't forget the one way valve in the hose...
looking really good there mate... just about to send u a PM about the weekend now.
Dave
Dave
For a little extra$$ Dave should wire the fans on relays for you..., So fans have plenty of power and don't let the engine get hot:)
Just my 2cent worth..
LOL i just said that to him in the PM i sent him Guy... lol... obviously an optional extra.
Dave
Dave
Ok so a nice early start today,
Dave arrived and worked his magic with the wiring loom,
all went well besides for afew little things like one fan wasn't working properly so I got it swapped for another one.
But the main thing is that it's running
Started first go, so happy
now just putting all the fenders on and tiding up so wiring,
Only Thing left to do now is sort the engine mounts out, they are original mounts so the bolt with the wedge is to short for the nut the hold nicely on so I'm thinking i'm going to get after market mounts cause everyone is saying that they have a longer bolt, Please can someone confirm this?? and if so where to I get them from, I know it's a dealer thing But which one? has anyone got them recently??
Other than that she purrs like a kitten, love it
Thanks to Everyone who has helped along the way and give moral support, Really appreciate it,
Heres the final pic of the engine bay with everything done,
EJ22 finished by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
