Bantum's '85 Brumby ...
Collection of automotive design / construct projects by Bantum ...
Moderator: Bantum
Update :
Post by Bantum » Mon Nov 06, 2017 6:22 am
Bit of a thread dig - I haven't done much in the last few months ( as I've been busy doing other things ) but did manage to pickup a few items :
Something for the rear end ...
A Drive Shaft ...
Some spare parts ...
& something else to do :
Oh & had to move shit ... :(
Hope to have somewhere to work on it soon ... :/
Ciao, Bantum ...
Post by El_Freddo » Thu Nov 09, 2017 4:44 pm
Ooh, nice rear end addition!
And going for a 5 speed?
Diff Out ...
Post by Bantum » Fri Nov 10, 2017 2:07 am
Yep, I posted that up earlier :
showpost.php?p=236288&postcount=59
Have been slowly stripping it down / cleaning up & took it into get photographed as part of the R160 Locker Project ...
And front diff :
Plan is to take out the old Transmission & swap in this 5 speed ... :)
Note to Self - must remember to take some more photos next time ... :/
Bantum, Out ...
Slow going ...
Post by Bantum » Tue Sep 18, 2018 12:57 am
Sorry there's been a bit of a hiatus on the project ...
I haven't got round to doing much on Bantum due to several factors, will update this when I get round to it ... :(
( I'll also have to go back over old posts to update missing images etc . )
Did manage to pick a few items but :
Replacement windscreen : ( rubber is shot though )
and trims :
Cheers, Bantum ...
Trims ...
Post by Bantum » Fri Jul 24, 2020 5:27 am
Had some of these made up :
More info here :
https://photos.google.com/album/AF1QipP ... Er_0o2Q3uL
& cleaned up the front grill :
Repaired & painted the endcaps :
Came out pretty good :
Haven't got round to doing much else ...
Gear Boxed ...
Post by Bantum » Fri Jul 24, 2020 5:32 am
Made a box :
And stashed a few things in it ... :p
( As it will be sitting a while before much happens to it )
Also picked some old wheels to move it around the shed :
Plan is to referb the performance wheels later ... :)
Sidestep Install ...
Post by Bantum » Fri Jul 24, 2020 5:41 am
Before Cronovirus struck, I was in the process of sourcing some bits for the Sidesteps :
Hardware :
Cleaned up some of the mounting holes :
And proceeded to locate them :
Drilled & bolted on the back :
Test fitted the front :
Didn't have to drill any holes, but the splash guard needs to be repaired / replaced, so made a template :
And test fitted it :
Then marked it out on some signage sheet I found :
& Cut out with jig saw :
That was far as I got when things shut down ... :/
( was not able to travel to site where ute is located )
Hope to pick up where I left it - when things go back to 'normal' ...
Re: Bantum's '85 Brumby ...
Post by El_Freddo » Fri Jul 24, 2020 9:52 pm
Looking good Bantum!
The first image in your post about the grille restoration isn’t working for me :(
I love those side skirts. Might have to one day look into what I can modify to fit my brumby...
Sorry to hear you can’t access your brumby with the current restrictions. That would be mega frustrating!
Keep up the good work!
Post by Bantum » Sat Oct 31, 2020 3:31 am
Re-posted image for you Bennie ( will see if it holds )
Major hold up with fitting side skirts - Think I might have to 'deconstruct' the sub frame to strengthen it for the front mount ... :|
Still looking for a new place to move to ... :roll:
Ciao, Bantum ...
Post by El_Freddo » Sat Oct 31, 2020 12:37 pm
That grille looks mint.
And going back a long time now - those replacement doors were a real score, correct colour (enough to just do an external spray to colour match) and they appear to have power windows. Did you pull these from a coupe??
All the best with finding a new place. It can be very frustrating!
Post by Bantum » Sun Nov 08, 2020 9:44 pm
Yep the grill turned out ok ... ( still need to do the rest of it but )
The doors do come from a coupe, so will have swap out the glass when I get round to it ... ;)
Not looking forward to tackling this next problem though - will have to strip it down, clean up & fix the leaks ... :neutral:
Bit of a nightmare with all the plumbing ...
Ciao, Bantum ...
Post by El_Freddo » Mon Nov 09, 2020 6:40 am
That hitachi looks pretty clean for its age. Mine starts and runs, get me to work etc. not great fuel economy probably due to the constant work on the gearstick and a worn carby. On the open road after several minutes at 100km/h you can hear the engine slightly pinging. Put the foot in a little more and it disappears - unless going up a hill where you’re in that throttle area for a short period of time.
I’d like to resolve this but it’s looking easier to fit an EJ than to strip the carby down.
Other thought is oil vapour passing through the PCV valve at cruise.
My advice for you: take loads of pics as you strip away the layers of your carb so you know where everything goes.
Re: Carby ...
Post by Bantum » Sat Nov 14, 2020 9:18 am
Yes I have already taken loads of images, another trick is to label all the hose connections - Holding of doing this until I have some where decent to work on it ... :/
Update : Found another place to work on it so will be able to continue with project ... :)
Cheers, Bantum ...
Rust ...
Post by Bantum » Sun May 02, 2021 5:48 pm
After closer inspection of the donor doors, have found they had too much rust in them ... ( as did the original ) ... :/
So have sourced some new ones ... ( thanks to Daniel Elcoate )
& have some spares floating around that I'll need to get rid of :
Any takers ?
Windows ...
Post by Bantum » Fri May 21, 2021 4:22 am
Interesting side note :
Do note the differences between Coupe & Brumby window ...
Cheers, Bantum ...
Post by El_Freddo » Fri May 21, 2021 10:20 pm
^ I got caught out with that too.
Same for the L series rear door glass between sedan and wagon. This probably goes for the MY sedan/wagon and the Liberty too.
Did your coupe doors come with factory electric windows?
Powered up ...
Post by Bantum » Mon May 24, 2021 5:47 am
Yep, plan is to complete the powered window install with all parts I have collected to make it work.
Think I've got all the bits I need - just need to strip out the interior to install it now ... :/
Cheers, Bantum ...
Post by El_Freddo » Mon May 24, 2021 4:56 pm
I’m at the same point with mine too Bantum. The touring wagon console went in a while ago. Looks good and is very comfy for the left arm to rest on.
Now to sort out the actuators etc among everything else I need to do...
Updates ...
Post by Bantum » Thu Sep 02, 2021 4:13 am
Been a bit of faff dodging Covid Lockdowns, but did manage to pickup some bed trims ...
The door saga continues but, found the left door I picked up contained way tooo much filler ...
So on the hunt for another door ...
The rust issues are getting worse the more I look :
Post by El_Freddo » Thu Sep 02, 2021 4:35 pm
Pics no worky :(
Return to “Bantum’s Works”
