Alex's ej20g conversion
Shark
Post by Shark » Fri Aug 01, 2008 1:36 am
Must be a real pain taking all that wiring out and having to put a different bunch all in again..
How much extra power does this engine produce Alex?? Like supa tyre frying goodness??:)
MArc
Post by D3V1L » Fri Aug 01, 2008 10:14 am
100kw verses 154kw at the fly :D:D
BrennyV
Post by BrennyV » Fri Aug 01, 2008 10:23 am
D3V1L wrote:the subaru wacky workshop was alcohol free today:) its AMAZING what can be aceived when alcohol isnt present:P
dave
thats blaspheme in the religion of wacky workshop! you wash your mouth !!!
Hunter S. Thompson
Post by D3V1L » Fri Aug 01, 2008 10:35 am
ok ok...i might have had a couple of brews...lol
Shark
Post by Shark » Fri Aug 01, 2008 11:13 am
154kw=good times and great youtube video's:-D
Post by Alex » Fri Aug 01, 2008 11:27 am
its actually 162kw. Jap spec.
BrennyV
Post by BrennyV » Fri Aug 01, 2008 1:31 pm
skidz big time!
Hunter S. Thompson
Post by Subafury » Sat Aug 02, 2008 12:02 pm
cant wait for all the tyre frying action. - maybe buy some street tyres for cheap as part of the conversion. just for the front.
Post by Alex » Sat Aug 02, 2008 10:36 pm
are you saying im going to be doing lots of skidz/??
they will be minimal.
Post by Alex » Tue Aug 05, 2008 12:38 am
hit a big brickwall with the wiring. Will take afew extra days and $$$ than i expected. I knew it was all going to well! At least the engine bay came out hella sexy!
timing belts and rocker covers have all been done also.
Post by D3V1L » Tue Aug 05, 2008 12:43 am
mmm... yes... set back caused by devil dave...apologies offered :P..... ill sort it out for ya buddy.....dave obviously not as clever as he thought he was :(
dave
seagull
Post by seagull » Tue Aug 05, 2008 12:49 am
whats the problem Alex ? Dave ?
Post by Subafury » Tue Aug 05, 2008 9:02 pm
a wrx harness needs to be altered to fit the rs lib motor ive heard.
adamb
Post by adamb » Tue Aug 05, 2008 9:57 pm
hey guys,
hows sourcing the wrx engine loom going? any luck?
L Series current mods:
EJ20G, 3" lift, Roo bar, spotties, EJ Sporty steering rack, desert rats, 27" tyres, 2.5" exhaust
Post by D3V1L » Tue Aug 05, 2008 10:29 pm
all sourced and done..jsut gotta plug sensors in and we are away
dave
Post by Alex » Tue Aug 05, 2008 11:32 pm
more pics.
painted engine bay
got the new clutch back today. Got it beafed to 2800lb. VERY impressed with the clutch dudes work. Also got the actual clutch disc beafed to wrx spec, and all surfaces machined etc. Note the two diaphragms. It was he only way the clutch guy could get soo much pressure into the l-series pressure plate.
Also strengthened the clutch fork today and installed new thrust bearing.
chopped out the xmember to suit the turbo piping.
Put the WRX engine harness onto the motor(tedious long winded bitch of a job) looks like everything will connect sweet.
And attached the adapter plate onto the motor.
The motor will go in tomorrow, just gotta do the main wiring harness and splice in the RS knock and cam sensors into the wrx loom.
Pray to dear god we dont come across any other problems!
SuBaRiNo
Post by SuBaRiNo » Wed Aug 06, 2008 8:41 am
So you swappped the harness but you still need to change the plugs on the knock sensor and TPS?
Dave
Post by Alex » Wed Aug 06, 2008 10:15 am
yes. The rs loom has the sensors on long leads, where as the wrx has a plug which goes directly onto the sensor. Some simple cutting and joining should solve it.
Post by D3V1L » Wed Aug 06, 2008 12:54 pm
nad dave the knock sensor and tps are now solved.....we just need to modify the leads for the cam sensor and crank sensor and thast all....we could go and buy the 2 sensors with the correct plugs on them but for $160 i think making these 2 fit will be easier
dave
Post by Subafury » Wed Aug 06, 2008 9:25 pm
lets see pics of the clutch fork beefing pls
looking very nice tho. test out this weekend i think :p
