This is what's believed to be an ej d/r from the land of Oz. Thanks.
I know what it's not. . . http://www.northursalia.com/techdocs...rannychart.pdf
Yep correct, it is I just looked up on my papers...seagull wrote:Its a 1992 gen 1 series 2 d/range 3.9 final ratio from what I can work out
so have you a rear diff for this ?
Ap this code ( box ) if I am correct came out in a gen 1 gx 4wd liberty as well .that was in 1991 .Is this reduction sort after ???AlpineRaven wrote:For one second I thought it was an Forrester Box from around 1996 but the number is wrong.. I know that 1996 Forrester with 1.447:1 reduction gear was TY752XH1AA.. sorry I'm not much of help. But only one thing is for sure its AWD box from EJ series.
Awesome, If I know I can do that, then I'm even happier. By "L" you mean Loyale/ea82correct? Those are a dime a dozen around here still.BYB-01 wrote:The low range reduction is not good. 1:1.192 compared to the Forester Impreza reduction of 1:1.5. This is the box that every one pulls apart and fits the L series low range and 4.111 diffs to.
It would be 1.19:1 reduction gear.seagull wrote:Ap this code ( box ) if I am correct came out in a gen 1 gx 4wd liberty as well .that was in 1991 .Is this reduction sort after ???
o and final drive was 3.9 rear ?
seagull
That's weird as I put an input Liberty gearset shaft up against an RX output gearset shaft and it matched right up, first to 4th and reverse all looked good. Didn't end up running the box like that though, cos I didn't need any of the Lib gear, just the case.discopotato03 wrote:Actually 4th gear is not direct in L or early EJ boxes . The closer or carby L / NA AWD Lib ratio 4th is a very slight underdrive and the RX and RS Turbo ratios 4th is a slight overdrive . Admittedly the differences are really small at 1.088:1 and 0.972:1 so 0.116 the difference .
Cheers A .
Yeah, originally, so I could make sure I had the right rear diff. But, with all this new (to me) info, I guess I'll be looking for a 4.11. Thanks.Phizinza wrote:Yeah, sorry. My use of words was poor and I don't think you understood. Don't worry about it. I'm pretty sure Zap only wanted the diff ratio anyhow.
