cam belt?
- INEEDABEER
- Battlewagon
All EA82's are interference free, EA82T's have a bigger dish in the piston so definitely no problem there.
Some early EJ's with the SOHC heads were non interference too, apparently
- littlewhiteute
You should use light valve springs (SU carb springs or similar) in a mockup build to check for valve to piston clearance,CPOCSM wrote:nope...if you are still squeamish...put some plasticine on the crowns and check yourself...peace of mind
Hooroo
and a dial indicator will show how much additional valve lift as piston nears TDC.
Allow for compressed head gasket thickness.
Gary
Gary
Why are you worried?
Even engines with valves that interfere with the piston run ok as long as the cam timing is right.
Because of the EA82's deep and narrow 'bathtub' combustion chamber, i doubt any valve will ever hit any piston as the piston is only as high as the deck of the block at TDC
