1998 Liberty Diff ratio
subaruby
Post by subaruby » Mon Apr 14, 2008 7:54 pm
I have a 1998 liberty 5 speed manual with low range, anyone know what the rear diff ratio is or how to find out?
Other than pulling it apart!
Suspension lift.
Post by El_Freddo » Mon Apr 14, 2008 7:57 pm
subaruby wrote:I have a 1998 liberty 5 speed manual with low range, anyone know what the rear diff ratio is or how to find out?
Unsure about how to find it with out pulling it apart Richard, but you should drop the L series low range in it while its out of the car... while your doing that count the teeth on the crown wheel.
What are you up to anyway? Sounds like you got an EJ conversion with the EJ box in mind... Let me know how it goes.
Cam
Post by Cam » Mon Apr 14, 2008 8:28 pm
iv got a 98 impreza d/r gearbox which has 3.9 diff ratios, think subaru would've used the same boxes?
Post by AlpineRaven » Tue Apr 15, 2008 6:43 am
Cam wrote:iv got a 98 impreza d/r gearbox which has 3.9 diff ratios, think subaru would've used the same boxes?
Nah... some are 3.7, 3.9, 4.11 etc
Post by AlpineRaven » Tue Apr 15, 2008 6:46 am
Look at the sticker on the gearbox and search it up. Is it Gen2 or Gen3 gearbox?
I have a feeling it might be 4.11 if it came from Gen3 Liberty? If its from Gen 2 Liberty its more likely will be 3.7.
That is why it pisses me off with wreckers who dont include or write down the rear diff's ratio and they goes "oh aren't they all the same!" *groans*
subaruby
Post by subaruby » Tue Apr 15, 2008 7:09 am
No conversion in mind el freddo, just thinking long term, wife drives the liberty at the moment. Thinking long term rear lsd and lift. Saw a lsd on ebay from 1999 rex claims to be a 3.9 and trying to see if it will fit?
Suspension lift.
FROG
Post by FROG » Tue Apr 15, 2008 9:10 am
if you throw me your vin number i should be able to work it out
bobbyjimmy
Post by bobbyjimmy » Tue Apr 15, 2008 9:15 am
Sorry to Hi-Jack, but anyone know what the diff ratio on a 2002 (Gen 3) Outback 2.5l Manual?
FROG
Post by FROG » Tue Apr 15, 2008 9:31 am
bj same.. throw me your vin and i should be able to work it out
yours is either 3.9 or 4.111
Post by El_Freddo » Tue Apr 15, 2008 10:26 am
FROG wrote:bj same.. throw me your vin and i should be able to work it out
Or stick your head up under the back of the car, the diff should have a sticker with the diff ratio printed on it. So long as you know no that no one has swapped the gearbox out it will be correct. My L series still has its sticker on it and that's an 1988 model...
Post by AlpineRaven » Tue Apr 15, 2008 10:25 pm
El_Freddo wrote:Or stick your head up under the back of the car, the diff should have a sticker with the diff ratio printed on it. So long as you know no that no one has swapped the gearbox out it will be correct. My L series still has its sticker on it and that's an 1988 model...
From Liberty onwards there never has been a sticker on the diff. Only MY and L Series did have a sticker. There was a Code but always wear off or falls off.
The only way is open the rear diff cover off to check the stamped ratios.
