factory headunit differences
Get wild & funky with your Mobile disco ...
brumbyrunner
Post by brumbyrunner » Wed Mar 26, 2008 11:48 pm
Are the Subaru double din headunits all the same mounting system?
Reason is, I've still got the orignal single din cassette/tuner in my 2000 GX Imprezzer and have a chance to buy a double din cd/cass/tuner out of a 2001 Forester.
So, will it bolt straight in and look factory? I dont really want to go aftermarket if I can help it. Just need a CD player.
Settlement Creek Racing
Matatak
Post by Matatak » Wed Mar 26, 2008 11:52 pm
the ones ive seen definitely look similar.....but i wouldn't rely on my response.
(ps. how many cars do u own? every thread u start seems to talk of another one lol)
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by Gannon » Thu Mar 27, 2008 5:29 am
I cant see why it wouldnt, nearly every part on a Subaru is interchangable with that of another model. Kinda like LEGO.
brumbyrunner
Post by brumbyrunner » Thu Mar 27, 2008 3:12 pm
Thanks Matatak & Suparoo.
I was kinda hoping for a bit more difinative answer than "it should fit" before I buy the 2 din unit and pull the dash apart.
brumbyrunner
Post by brumbyrunner » Fri Mar 28, 2008 9:43 pm
Oh come on!!!!!!!!!!!
Where are the sound gurus when you need them?
It either bolts straight in or it doesn't.
Post by D3V1L » Fri Mar 28, 2008 9:45 pm
the sound gurus ditch shitty stock crap in favour of more modern artwork :)
dave
Post by Gannon » Sat Mar 29, 2008 7:33 am
Well the DIN pocket mounting system for car audio is standard across all cars.
So yes it will bolt in, but there may be a difference in the facia surround that mightnt fit
Cant you take your Impreza to somewhere that sells 2nd hand Forester headunits and test fit it?
Outback bloke
Post by Outback bloke » Sat Mar 29, 2008 7:59 am
Impreza and Liberty are the same. Even if the Forester mounts are different you can unscrew the brackets from the units and screw the Impreza one on.
schultzie
Post by schultzie » Sat Mar 29, 2008 9:40 am
under the current head unit im guessing you have a tissue pocket? if so then when you take the single din unit out and the tissue pocket you will get ur double din , there should be enough there to mount it off, so i say give it a go :D
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
brumbyrunner
Post by brumbyrunner » Sat Mar 29, 2008 10:02 am
OK thanks guys.
I thought if there was a glaringly obvious difference or difficulty in fitting then someone would have told me so I'll give it a go.
Bumpty
Post by Bumpty » Mon Mar 31, 2008 3:08 pm
haha... You've created a masterpiece (read - Brumbyrunner) and you are worrying about stereo head units, nice to see you are still human :)
brumbyrunner
Post by brumbyrunner » Mon Mar 31, 2008 7:03 pm
I feel the need to explain....
This is for my mothers car. She wants to play CDs but still retain the cassette player as well. I looked at going aftermarket but it would be overkill for the application. Plus the rest of the car is stock and a big shiny double din headunit would just look silly.
schultzie
Post by schultzie » Mon Mar 31, 2008 7:14 pm
just as well i never questioned it then... oem usually looks the neatest as well...
brumbyrunner
Post by brumbyrunner » Fri Apr 11, 2008 10:49 pm
Well it's a success!
Looks stock but sounds ohhh so much better.
In case anyone else ever wonders about doing this upgrade and finds this thread, it is very easy, perhaps a 15 minute job. Our new double-din headunit came from a wrecked 2000 Forester so had a 6 disc in-dash stacker, tuner & tape deck. The mounting points and plugs were identical, right down to the earth tab and the little locating dowls.
Total cost was $160 and that included the 6 discs that we found inside!
Post by Gannon » Sat Apr 12, 2008 7:15 am
Congratulations, and you wouldnt take our word for it when we said "it might or should fit"
What discs where in there?
Bumpty
Post by Bumpty » Sun Apr 13, 2008 8:07 am
haha nice! Great score with the Cds as well... what were they?
KevinFlys
Benefits of Becoming a Member
Post by KevinFlys » Tue May 27, 2008 1:34 pm
Can you simply tell if Runescape is a great game maplestory powerleveling or not without you becoming a member? The answer to that would be, NO! Well you can make a few predictions about Runescape and see the moral of the game when being a regular user and not a member but becoming a member brings a whole lot of additions to Runescape that you would never see if you were not a member. Being a member of Runescape has so many benefits and I will try to list them all here for you. Runescape tells you them, but I'm going to detail it a few features for you here. runescape money
stinky
Post by stinky » Tue May 27, 2008 3:29 pm
brumbyrunner wrote:Well it's a success!
Good to hear ... the new brumby has a liberty double din headunit in it, so will keep my eyes open for any wrecked fozzers.
Return to “Sound / Entertainment Systems”
