Knock in the EA82
Dutchy
Knock in the EA82
Post by Dutchy » Thu Feb 28, 2008 4:29 pm
I hav an EA82 carby with a really bad knock in it (its really nasty)
I recently done the lifters and front cranck seals, re-sealed the heads and re-built the oil pump but it still is knocking.
Any suggestions to why it is still doing this would be greatly appreciated...
Scott
BrennyV
Post by BrennyV » Thu Feb 28, 2008 4:32 pm
i know its a bit of a no brainer but u did prime the oil pump before you ran it up?
Hunter S. Thompson
Dutchy
Post by Dutchy » Thu Feb 28, 2008 4:42 pm
BrennyV wrote:i know its a bit of a no brainer but u did prime the oil pump before you ran it up?
Prime the oil pump. i done the lifters but i didn't think that u hade to d the oil pump...
BrennyV
Post by BrennyV » Thu Feb 28, 2008 4:44 pm
its always a good idea mate. how long have you run it up for?
Hunter S. Thompson
Dutchy
Post by Dutchy » Thu Feb 28, 2008 4:51 pm
Ive ran it for about 2 weeks im sure we primed the engine before we started it we hooked it up to a spare battery disconected the lead from the distributer
and let it tick over till the battery went flat.
I even asked a mechanic and they seem to think that there might even be a gap between the lash adjuster and the crank because is only on the drivers side.
madmat
Post by madmat » Thu Feb 28, 2008 4:52 pm
i had a similar issue and a tiny pieace of dirt had blocked the oil supply restrictor to the heads.
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
BrennyV
Post by BrennyV » Thu Feb 28, 2008 4:55 pm
madmat wrote:i had a similar issue and a tiny pieace of dirt had blocked the oil supply restrictor to the heads.
ive seen silicon do this also.
Hunter S. Thompson
EL TORO
Post by EL TORO » Sat Mar 01, 2008 9:43 am
Try a oil change and use a quart of lucas oil. My rig was loud as hell till I put in the stuff. Some times those lifters need a little help. Knocking went away in one day of driving for me. Hope it helps...
warning- left hand drive
gx_rex
Post by gx_rex » Sat Mar 01, 2008 7:52 pm
all else fails I have a low k's imported ea82 sitting at dads place for $500.
Already put a new timing belt on it etc before we changed plans.
Matatak
Post by Matatak » Sat Mar 01, 2008 8:03 pm
its not just a lifter tick...
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Dutchy
Post by Dutchy » Sat Mar 01, 2008 8:06 pm
EL TORO wrote:Try a oil change and use a quart of lucas oil. My rig was loud as hell till I put in the stuff. Some times those lifters need a little help. Knocking went away in one day of driving for me. Hope it helps...
done that as well. I put a higher grade oil in it it quietened down a little but not much..
Dutchy
Post by Dutchy » Sat Mar 01, 2008 8:08 pm
gx_rex wrote:all else fails I have a low k's imported ea82 sitting at dads place for $500.
Ill get back to u on that 1 see if i can fix this first.
Dutchy
Post by Dutchy » Sat Mar 01, 2008 8:18 pm
Matatak wrote:its not just a lifter tick...
Well its something on the lifter but only 1 on them. i remeber 1 side was that rooted that there was a bur around the lifters holding them in place but we got rid of that and put all new lifters in. I think 1 of the valve springs have gone soft, leaving a gap between cam and the lash adjuster, but still unsure been tryng to fugure it out for a couple of weeks
Post by El_Freddo » Mon Mar 03, 2008 1:02 pm
another problem can be the oil pump is sucking air and airating the oil. My sister's L had the seals IN the oil pump changed but we failed to replace the shaft seal. It took a 3000km trip to seal it up from dust/dirt etc. Sounded like a diesel before this happened - real nasty.
Dutchy
Post by Dutchy » Mon Mar 03, 2008 5:17 pm
[quote="El_Freddo"]another problem can be the oil pump is sucking air and airating the oil. My sister's L had the seals IN the oil pump changed but we failed to replace the shaft seal. It took a 3000km trip to seal it up from dust/dirt etc. Sounded like a diesel before this happened - real nasty.
the oil pump is fine we rebuilt that aswell and checked it yesterday to see if it was actually putting oil on the cams.
Post by El_Freddo » Tue Mar 04, 2008 9:30 am
Dutchy wrote: the oil pump is fine we rebuilt that aswell and checked it yesterday to see if it was actually putting oil on the cams.
Don't get me wrong, the oil pump will pump oil, but at engine speed and temp it may find it easier to suck a little air into the system than suck the oil from the sump...
All of this said, you may not have this problem at all, i'm just coming in on another angle ;)
Matatak
Post by Matatak » Tue Mar 04, 2008 7:41 pm
i think a soundclip woudl help everybody.
to me its sounding like u got a Dead Lifter or one that doesnt have any oil getting into it.
they can rattle like hell when theres absolutely no oil in them
