Will 16x7 superlites fit under a Vortex/Leonie
vortexxt
Post by vortexxt » Sun Feb 03, 2008 7:33 pm
Howdy all,
I own a Vortex and interested to hear if anyone has tried fitting 16x7 Superlites?
I know the 15x6's fit aok with 205 tyres, but would much prefer a 16" rim running 205x45x16's
Cheers with beers
Johnno
Chris_Rogers
Post by Chris_Rogers » Sun Feb 03, 2008 8:35 pm
yes - BARELY. rear arches need to be lipped. had a set of simmons P86 (mesh rim with solid centre.) under my old one.
ride will be rough though. it will handle a LOT better than it did on the stock 13's and you will notice a difference from 15's. would help if you did the suspension at the same time.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
vortexxt
Post by vortexxt » Sun Feb 03, 2008 8:38 pm
Cheers Chris,
Will ring Performance and see if they can do the 10 spoke Superlites in a 16x7 as their web site shows only the 8 spokes in 16x7 and the 8's can't be had in 140x4 pcd!
It won't be my daily driver so will deal with a crappy ride :-)
Johnno
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Feb 03, 2008 9:50 pm
On an L series the 7in wide rims stick out a fair bit, i think you wil be fine on the rear but may have to pump the fronts out to cover the wheel.
The long road ahead
Chris_Rogers
Post by Chris_Rogers » Sun Feb 03, 2008 10:21 pm
front is fine. rear will foul on the guards hence why I said to roll the rear guards.
Audio Express
SUBYDAZZ
Post by SUBYDAZZ » Sun Feb 03, 2008 10:38 pm
Will depend on the offset of the wheels.
SUBYDAZZ
