Outback - largest battery replacement
Seems I need to replace the OBW battery in a hurry.....can anyone let me know what big bad ass battery will be able to fit, other than standard, which I guess isn't too bad, but.....
- vincentvega
I've got a larger than OEM battery in my Outback, but needed to also fit a larger battery tray. The battery fits okay - even has a bit of space (~ 20mm) for clearance from the body and engine.
GS Yuasa 68
http://www.gsyuasabatteries.com.au/file ... 0Sheet.pdf
GS Yuasa 68
1999 Outback (some mods)
1989 Brumby (more mods)
Subaru - Symmetrical All-Wheel Drive
How come you need bigger battery?
get a bosch gold. Ive got one in both my wagon and liberty. AWESOME battery for the price. I can run my stereo all day long and it wont even hesitate to crank over.
We wanted a battery that would comfortably power common camping items (light, radio, etc) for an overnight stop, and still have enough juice to crank the engine.AlpineRaven wrote:How come you need bigger battery?
Went and spoke to a few auto elecs, and some battery world people about what we wanted to run, and the general consensus was that a larger cranking battery (one fitted with thicker than standard plates) would meet our needs.
We did consider keeping the standard size battery and run a portable AGM battery in the cargo area (removeable battery box), but given that we don't use a 12 volt fridge it's overkill - and a more expensive option.
- vincentvega
I did the same thing in my lib, i have a marine starting battery thats almost twice the size of the stock battery. I have only once had to be jump started, and that was after 10hrs straight of my carPC + big stereo running
Fair enough yeah no worries. For me i don't have a good reason for a bigger battery.Jack wrote:We wanted a battery that would comfortably power common camping items (light, radio, etc) for an overnight stop, and still have enough juice to crank the engine.
- Suby Wan Kenobi
I put an Optima Red Top in my 01 RX Liberty back in 2000 and it is still alive in my 03 XS Forester but if you are running Audio setups or fridges etc then go the Deep Cycle Yellow Top, 7 yrs is a good run for your money.
Peter
- discopotato03
A little exy but really a diode switch and a second battery (deep cycle) is the nice way to do it .
On the cheap I suppose you could run two batteries and have a isolator of some sort to keep one for starting .
You just have to be a bit careful about running a lead acid battery completly flat because the plates sulphate up and they won't accept a charge .
The issue with one battery even a large one is that once its flat its flat .
LOL buy a manual and camp on a hill ?
Cheers A .
Cheers A .
- SUBYDAZZ
I just took a couple of measurements with a tape measure and had a browse at what was on offer when I did mine. Just went for the highest CCA & RC I could find that would physically fit. When going for a larger battery I have found that they are likely to last a lot longer than what a standard battery should also. THey say 3-4 years is normal for a battery, but for my last one I got over 6 years (in 2 different cars).
Bear in mind 3 points though:
The terminals may be a different size than standard (not hard to adapt to)
Take into account the height of the terminals, not just the battery itself.
There are several configurations of terminal location, make sure they're going to fit your leads (again, not too hard to fix)
SUBYDAZZ
- vincentvega
I think the only reason you get longer life out of larger batteries is because even when they are stuffed, and only at say 50% capacity, thats still more than enough to start your car.
My marine battery is about 4 years old, and I amsure its on its way out. You can see the plates are erroded looking inside it and there is lots of crap floating around ikn the electrolyte.
That said, it starts the car fine since its such overkill.
I think it will be relocated to my boat soon, so a new one can find its way into the car before i head west next year
also a tip for Gen1 guys - Jap Gen1 / Gen2 run a larger battery (for the snow) that has a larger battery tray. This fits perfet in Gen1. I fitted this tray then filled it with as much battery as possible
- Suby Wan Kenobi
