Just installed Air/Fuel Ratio Gauge
Post by Gannon » Thu Dec 06, 2007 6:08 pm
I bought a Air Fuel ratio Gauge off eBay last week and i installed it this arvo.
Red wire went to pin 19 (Ignition Power)
Grey wire went to pin 48 (O2 sensor)
Black wire went to ground
Easy as.
I have a new O2 sensor and when cruising, the leds sweep back and fords (from lean to rich) quicker than the eye can see. So obviously our ecus arent as slow as we thought.
The moment i put my foot down, it stops sweeping and only lights 1 or 2 leds. It gives you a really good idea of when the engine is in closed loop / open loop mode.
The only thing is that as i accelerate at WOT, as the engine nears 4k rpm, its leaning out. I will have to hook up a fuel pressure gauge and check my fuel pressures.
While im here, i'll show off my boost gauge that is recessed into the dash surround
timmo
Post by timmo » Thu Dec 06, 2007 6:37 pm
on a side note what did your surging problem turn out to be?
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Post by Gannon » Thu Dec 06, 2007 6:54 pm
dunno, ive still got it
But if its leaning out, then pinging, then retarding timing, that may be the cause of it
Time to break out the fuel pressure gauge
Matatak
Post by Matatak » Thu Dec 06, 2007 9:35 pm
get me the link to that A/F guage :D
sweeping back and forth is what they shuld be doing yer when cruising.
i need to no if mines running rich lol
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
SuBaRiNo
Post by SuBaRiNo » Thu Dec 06, 2007 10:44 pm
Both your boost gauge and your fuel ratio gauge is the exact same as mine.
Dave
Post by Gannon » Tue Dec 11, 2007 6:57 pm
Here is an ebay link to what i bought
52mm Autometer Air Fuel Ratio Gauge
