TMIC vs FMIC
BlackMale
TMIC vs FMIC
Post by BlackMale » Fri Nov 09, 2007 1:55 pm
In the interest of me being lazy (read v busy atm) and no current Tech manual (oh and i am not having a shot at anyone with this point either), Does anybody have any info on cost/benefits/testimonials/comparisons on TMIC vs FMIC, specifically for a lil EA82T, however other info is welcome.
(Sorry if its not the best section ot post this in).
Thanks.
Post by AndrewT » Fri Nov 09, 2007 2:24 pm
Don't have much direct experience with EA82's and their intercoolers but everyone is entitled to my opinion :)
I think for an EA82 probably just a top mount will sufficient This will be a good upgrade over the standard situation (no intercooler!).
A front mount is obviously better (altho a slight increase in boost lag is experienced usually), and naturally there is a fair expenditure required to get all the pipes/bends fabricated up and installed. The benefit however probably won't be realised with an EA82 unless you have a wild motor running a larger turbo and huge amounts of boost.
A person could nearly upgrade to an EJ22 for the kind of money likely involved :)
The Bigfella
Post by The Bigfella » Fri Nov 09, 2007 2:27 pm
I'm very busy too. Busier than you.
So, here's a tip
Results 1 - 10 of about 7,190 for TMIC vs FMIC. (0.57 seconds)
(sorry guys - pet rant of mine for people who won't use search buttons)
Post by D3V1L » Fri Nov 09, 2007 2:54 pm
for the ea82t use a top mount...the front mount will always result in a greater amount of lag, AND more expensive in 99% of cases.
the best option in my point of view is the water to air RS liberty intercooler..much moore effecient then air to air AND cheapish. AND no need for a bonnet scoop or exposed front mount for the world too see (depending on your preferences heheh)
dave
The Bigfella
Post by The Bigfella » Fri Nov 09, 2007 3:18 pm
I just bought one off Sven2 - he may still have the other available - if you take the time to look you may find the thread in classifieds
BrennyV
Post by BrennyV » Fri Nov 09, 2007 3:37 pm
D3V1L wrote:for the ea82t use a top mount...the front mount will always result in a greater amount of lag, AND more expensive in 99% of cases.
dave
+1 for the waic for the ea82t would be the best by far.
fmic is only an option when ur tuning is limited by your tmic also with larger turbos were u cannot use a tmic setup. I run a hks piping kit and core that has a small pressure drop, but I still lost slight response and spool time only slight tho!
Hunter S. Thompson
daveosubi
Post by daveosubi » Fri Nov 09, 2007 3:40 pm
dave
I think this sounds the best, and from my thinking it would also suit offroading better with the slow speeds, they have a fan on the heat exchanger dont they?
You would also have a better chance of it being driveable if you have a small hit in the front, you could only loose water and not damage the pressurized intake, so you could limp home or back to camp.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Nov 09, 2007 4:11 pm
After all the info i gathered before fitting an intercooler to my RXi found out that the RS WAIC generally has issues with performance over 170KW atw so with even a really heavily modified EA82T that should be fine. I have previously had a Top mount WRX air/air IC on another EA82T powered L. It was fine on the highway but offroad it suffered badly with heatsoak even with a fan under it. The WAIC on the RX hasnt had any problem other that the bearings in the pump starting to become audible now.
Another vote for the WAIC.
The long road ahead
Post by D3V1L » Fri Nov 09, 2007 4:33 pm
awk...are u sure bout that 170kw??? i know several cars over here running in excess of 200kw atw and standard water to air with no issues in their liberties
dave
BrennyV
Post by BrennyV » Fri Nov 09, 2007 5:54 pm
i think perrin do a mega waic setup for track cars ;)
OOOOOOOO YEH
Hunter S. Thompson
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Nov 09, 2007 8:55 pm
There was a write up about it on the RS forum from Adrian Vos and using his chip and different turbo setup he noticed that 170kw atw was where boost went up but the cooling effect went down. That is an about quote for power but the instance here is not running an EJ20T with a WAIC but running an EA82T with WAIC and to be honest if you are getting more than 170kw atw with an EA82T your a legend and should be going front mount.
The long road ahead
subanator
Post by subanator » Fri Nov 09, 2007 10:44 pm
dave
When I had my EA82T I was looking at this option too, WAIC from RS needs additional radiator cooler for its closed system plus pump, hoses and control gear, probably find its a tight squeeze to get another cooler in the front.
I was talking to Tim at Sik Em Rex and he said for the small flow for this motor (compared to EJ turbo's), a top mount will do fine, dont go too big on cross sectional area, an earlier WRX one is near perfect or even the one off the Turbo Mazda RX7 is ok too.
As Dave says, lag is the factor here, not what you want for 4WDing.
tim_81coupe
Post by tim_81coupe » Sat Nov 10, 2007 1:55 pm
Another vote here for the WAIC.
I am running one in my RX and in my MY. I haven't finished the MY so I don't know how its going to affect the performance (the MY will easily make more than 170kw atw) but the one in the RX is brilliant!!!
I have a slight twist on the WAIC in the MY too - I am certain I won't have high temp problems.
If you go for a topmount air/air jobbie you'll need a yellow sticker... oops I mean a scoop.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Post by AndrewT » Thu Nov 15, 2007 1:07 am
heh Tim......if Jaffa hasn't got a yellow sticker already driving around like this...
....he's probably never going to get one!
SuBaRiNo
Post by SuBaRiNo » Thu Nov 15, 2007 8:06 am
But he did get one AndrewT. Since had it removed though. I don't belive that people get stickered for there scoops but i do belive that they catch the eye of the cops which makes them think more about pulling them over to get a closer look.
I need a intercooler for the hatch so i have been watching in here. But i don't want the extra attention that seams to be followed by having a scoop and unless there is some sort of MINI waic available i might have to go with top mount and scoop it anyhows. I also think i would have serious issues when it comes to adding another radaitor to the front of the car for WAIC.
It seams that neither of these types are exceedingly better than the other... more so it depends on the individual car, what it's running and the amount of space they have left in there engine bay.
Dave
Post by AndrewT » Thu Nov 15, 2007 9:01 am
Yes I know he had a scoop, u can see it in that picture. I was more referring to the Bunnings job on the side. ie, having a scoop is probably less of a worry.
schultzie
Post by schultzie » Thu Nov 15, 2007 6:01 pm
Waic FTW, intake temps are awesome and they dont heat soak like the top mounts,
and if u want even better inlet temps put a small bonnet scoop on, i have an XW scoop on mine and a big hole cut out and i have managed to get my inlet temps to 10-15deg above ambient while cruising and under boost it is stayign a lot cooler in my engine bay... gotta be a good thing.
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
SuBaRiNo
Post by SuBaRiNo » Thu Nov 15, 2007 8:09 pm
Got any pics of that scoop.
Dave
seagull
Post by seagull » Thu Nov 15, 2007 11:33 pm
I am fitting a WTA on my Ej207 , I let you know how it goes
discopotato03
Post by discopotato03 » Fri Nov 16, 2007 7:06 am
I think all things considered the early WRX/Liberty RS system is convienently packaged and affordable . If you have the spider manifold manifold it just goes on the back like with an EJ . Spare wheel has to move though .
Gee mentioned that a spider turned around (yes it unbolts from its bases so thermostat stays where it needs to) has its TB facing forward so charge pipe lengths to an FMIC would be shorter .
While a top mount air to air core is reasonably easy to fit they don't always cool when you need them to .
Cheers A .
