bloody cars
Captain Obvious
bloody cars
Post by Captain Obvious » Sun Oct 21, 2007 8:20 pm
looks like my motor has to come out and have the head gaskets done, the car has been doing this on and off for a while but since it has warmed up it has gotten worse, do a long drive slow down or stop,
the temp goes up and it spits all the water out of the over flow, stop let the pressure out and refill it its ok for a few days then the same happens.
was down at the mechanics the other day and he out the sniffer thing on the radiator and a was positive for the gases!
no water in the oil but i think there has be oil in the water for a while.
cheers
bryan
Suba
Post by Suba » Sun Oct 21, 2007 8:35 pm
bit of a bugger , but think how much better it will go when finished.
Mike.
Post by El_Freddo » Sun Oct 21, 2007 8:38 pm
All so get your radiator rodded while the engine's out, that way you know its clean with the fresh head gaskets and should be pretty hard to overheat unless your thermostat has carked it...
Outback bloke
Post by Outback bloke » Sun Oct 21, 2007 8:49 pm
Don't just do gaskets. Spend the extra $100 and have the heads shaved to make sure they are flat.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Oct 21, 2007 9:50 pm
If you dont know how many Ks are on that motor you may also consider a bit of a freshen up too
The long road ahead
Wilbur
Post by Wilbur » Mon Oct 22, 2007 9:52 am
You want that VRS kit then ?
Ben
Post by Ben » Mon Oct 22, 2007 12:04 pm
Buy a new motor, there's that many of them up your way surely they give them away nowadays?
Please watch before posting!
The Bigfella
Post by The Bigfella » Mon Oct 22, 2007 12:33 pm
Don't leave it too long - you run the risk of it sucking water into the bore as its cooling down. I did a head gasket at a track day at Winton this time last year in my BMW M5. It also blew the radiator with the pressure. $10,000 later things are fine again (and that was with me doing the labour).
I second the idea of a freshen up. Then you've got an engine you know is good.
Wilbur
Post by Wilbur » Mon Oct 22, 2007 12:43 pm
Bryan is getting this one done up. Just slip all those power up bits on now and I'm sure Bec won't even notice :D What's that credit card number again ?
Captain Obvious
Post by Captain Obvious » Mon Oct 22, 2007 9:26 pm
yep getting the heads skimmed and putting most of the vrs kit in it, it has never really seemed to use ant oil so id say the rest is ok, cant wait to have it going good again. as for buying a new motor, all this stuff will need to be done in it at some stage any way!!
its getting a new clutch while its out so it will be a totally different car!!
bryan
Return to “Trouble Shooting”
