had practically no warning at all except for some minor clunks that i thought were cv spline related tht started when i changed diff a couple weeks ago.
anyways left from uni today for the long stretch down the freeway (20-30kms) and immediately heard some random clunks happening from the back. pulled over checked all cv's etc, couldnt work it out. kept going. rear of the car started having a mind of its own, randomly starting to slide around like drift style. noises got worse as speed got up to about 70kms. pulled over again still no evident cause. ended up travelling home at 50kms an hour. then almost home i lose brakes- have to pump them 4 times to get a response- then i see the wheel wobbling and smoke start coming from wheel. arrgh! it almost caught the hub on fire when i stopped at home, had to put out the smoke.
after crakin it apart what i guessed had happened. bearing seized and friction causing bits to bend and disentegrate.
burnt and mangled bits. the inner race was screwed as i could push all the 'balls' from the ball bearings out
wheel came off with drum cover
see the dimpled bit here on the left? is this normal or has it bent out?
i just wanna know if its safe to just replace the bearings (with sealed ones)- looks ok to me.
