ea81 -ea81t
ea81 -ea81t
Whats need to change a stock ea81 motor into an ea81 turbo can it be done intake manifold and injectors can be sorted
cheers
camo
cheers
camo
The EA81t has different heads to the EA81 carby, as the injector bosses are in the actual heads themselves, unlike the EA82T which has the injectors in the intake.
The EA81t will also have lower comp pistons and an oil inlet and outlet port on the head for the turbo.
You would probably be better gettin a complete motor.
and a word of warning.... I started out buying a turbo crossover pipe on ebay for $18, intending to wack a turbo on my gas EA81 then my parts collection got out of hand. I now have an L series auto turbo sedan EA82T now goes !, a spare rolling shell with turbo 4WD compliance plate as well, enough bits to build another motor for my other Brumby, spare the bloody rusted out metal hoses.
Becomes very time consuming to learn and clean all the bits and get it al back together and running
And thats the fun of it! If your keen to do it and know what its all about but still have some questions, someone will know.jono wrote:and a word of warning.... I started out buying a turbo crossover pipe on ebay for $18, intending to wack a turbo on my gas EA81 then my parts collection got out of hand. I now have an L series auto turbo sedan EA82T now goes !, a spare rolling shell with turbo 4WD compliance plate as well, enough bits to build another motor for my other Brumby, spare the bloody rusted out metal hoses.
Go for it, even if its a learning curve and you say you should'a gone for an EJ20G or something a little more substansial.
and after pulling my old EA81 apart this arvo in no time and heaps less parts than an EA82T I was thinking to myself "still need to turbo this baby when i replace the CACTUS middle crank bearing, heaps less parts if it breaks"
Jeff, you say suck through which also means draw through which should mean the turbo sucks the air and mixture through the carby - what sort of carby and where was it ??
I think this is a drawthrough setup, Homemade turbo setup
If you do drawthrough, you need to add extra seals to the compressor side of the turbo because at closed throttle, it will experience manifold vaccum, and without the seals, will suck in oil
- Suby Wan Kenobi
deffently agreed i spend like 1300 buks on a ea81 n its still hell slowSuby Wan Kenobi wrote:Dont stuff around with the EA81 in search of power go the EJ22 and save yourself a heap of hassle
but yer its still a stock engine which is good 4 a P plater (well soon)
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
- littlewhiteute
That's a blow through, not a draw through.Suparoo wrote:I think this is a drawthrough setup, Homemade turbo setup
Carb is in stock location and pressurised from turbo.
Gary
Gary
Woops!
It is a blow through, my mistake
In which case, you will have to pressureise the float bowl to prevent underfueling
