brumby 4 speed with ej22
90brumby
Post by 90brumby » Tue May 22, 2007 12:30 am
hi just wonderin how well the standard 4 speed gbox in the brumby will hold up if it had an ej22 bolted to it
n if it will crap it self very quickly how esy is the Lseris 5 speed g box
cheers Tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
dfoyl
Post by dfoyl » Tue May 22, 2007 7:00 am
From memory, the 4 speed can handle 90 hp and an EJ can produce a fair bit more than that so I wouldn't recommend it unless you have a light foot :mrgreen:
If you're changing engines, you might as well put the 5 speed in at the same time. You'll need an adaptor plate either way...
Dean.
Post by El_Freddo » Tue May 22, 2007 10:05 am
Hey 90brumby,
If your going to drop the EJ in and a 5 speed why not go the EJ dual range box at the same time?
This will save time in the construction of the adapter plate. That said, you can spend that time on changing the low range to the L series low range: There are posts here to show how to change the EJ 1.19 low range to the L serie 1.59 low range if you want to go that far (from what i've heard it's recommended to do this if looking at some fun off-roading). And you get the advantage of AWD, in a brumby i'd imagine that'd fast become a quick car with all 4 wheels driving...
My 2c
SuBaRiNo
Post by SuBaRiNo » Tue May 22, 2007 9:29 pm
Your funny Tristan... talk to me on MSN dude.
Dave
90brumby
Post by 90brumby » Tue May 22, 2007 11:22 pm
alright dave it cause ive just put a new clutch in my 4speed
yer alright ill talk 2 ya on msn
KERAZY
Post by KERAZY » Wed May 23, 2007 6:12 am
when are you doing this conversion if you don't mind my asking?
Post by AndrewT » Wed May 23, 2007 9:04 am
90brumby wrote: yer alright ill talk 2 ya on msn
Dont forget to jot down anything else u might discover on this, I'm sure those following the thread will be interested :)
Post by steptoe » Wed May 23, 2007 9:26 am
surely gonna depend on how you drive it. sorta reminds me of the xmas parties the used car dealers used to have. each yard would take along the 'dog' that had not sold, put 'em all together, rig throttle to flat out and leave them to self destruct. one year the winner was an austin 1800
Phizinza
Post by Phizinza » Wed May 23, 2007 12:37 pm
I haven't split open a 4sp yet but looking at the 4wd gears and knowing they are very similar inside to a 5sp I would think a 4 speed in good condition would be alright. Although if your reverse gear is already poping out sometimes you will most likely have a problem there.. The 4sp's reverse is weak.
90brumby
Post by 90brumby » Wed May 23, 2007 1:58 pm
AndrewT wrote:Dont forget to jot down anything else u might discover on this, I'm sure those following the thread will be interested :)
alright but my bet is thaat he will say use Lseries 5 speed
90brumby
Post by 90brumby » Wed May 23, 2007 11:44 pm
alright basicly the L series is a much stronger g box that will beable to handle the power of an ej22
the clutch on some late model ea81s is the same as the ea82
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun May 27, 2007 7:16 pm
We have completed a few EJ conversions to MY series 4 speeds and have not had any trouble with the 4 speed box handling the power, any gearbox will break if you abuse it, however after a few months we are usually changing the 4 speed out in favour of the 5 speed.
The long road ahead
