L series and Liberty clutch fork difference??
Has anyone sat an L series and Liberty clutch fork next to each other to see if there is much of a difference??
Would a lib fork work on an L box??
Dave
Dave
i think i got one sitting around. ill have a look
Hunter S. Thompson
Hunter S. Thompson
thanks mate
Dave
Dave
Just ripped the fork of the liberty box.. doesn’t look exactly the same but doable.. ill test fit it to a ea box tonight prolly when I go have a play on the Leone
Hunter S. Thompson
Hunter S. Thompson
if you still need a picture of the fork - I have spare one here (Liberty one)...
Yeah that would be great... so far i have only looked at some pics in the Gregories manuals... conveniently the photo they have of the forks has simply been directly copied out of the L series manual.
Dave
Dave
Here they are..
When I put my EJ gearbox into my L series it was missing the fork. I tried fitting an L series fork to it - it was way off. Absolutely no way it would fit. The main problem was the pivot point (dimple bit) was in a completely different position. Consequently I had to source an actual EJ fork. After all of that I discovered there were even slight differences in EJ models of forks too.
As far as I know all EA ones are the same though.
I'll be at my house tomorrow, I'll see if I can try sticking the spare EJ fork I have onto one of my EA boxes and take a photo for you.
EZ30 L series - Monsterwagon
Thanks fellas
Dave
Dave
I am running a Liberty clutch fork on my "L" series gearbox.
Fits no problems, It is a little longer & has a bigger curve. It makes the pedal feel lighter.....
http://www.subiparts.com.au
0438 887 746
0438 887 746
Lighter is a good thing.... have you got any other details on what model liberty... 2wd?? AWD?? Etc?
Dave
Dave
Also... in your opinion would the Lib one be stronger??? I think i have busted my sencond one now... they keep splitting at the pivot point where it clips to the gear box.
Dave
Dave
It was from an AWD gearbox. Stronger... don’t know I would assume that they would be in better condition as less age & Kms.
0438 887 746
0438 887 746
