Front control arm bolt (L)
MY_STI
Post by MY_STI » Wed Apr 04, 2007 5:07 pm
The 10mm (shank) bolt that holds the control arm onto the crossmember.
Has anyone ever sheared, bent or broken one of these?
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
Captain Obvious
Post by Captain Obvious » Wed Apr 04, 2007 6:36 pm
no not that i have ever seen?? why do you ask??
bluesteel
Post by bluesteel » Wed Apr 04, 2007 6:45 pm
maybe yes... maybe no
i had one dissapear on the highway doin abuot 120 clicks when i hit a bump, pushed the wheel back onto the wheel arch/firewall and locked up. tad scary that one ;)
dont know if i fogot to tighten it or it broke... could have been either
MY_STI
Post by MY_STI » Wed Apr 04, 2007 10:23 pm
!!!! a change of underwear would have been in order after that johnny!
Reason I ask is because I am making some very hard front bushings tomorrow morning, was thinking of picking up a larger diameter bolt as the standard item looks a little lacking next to the beefed up (modded) arms.
If I use larger bolts the cross member should be reinforced (even) more, etc.
Might just get some grade 12 bolts in the standard size.
The vehicle will be pushed, hard.
