Speedo Cable ea81-ej20t
Clearwater99
Post by Clearwater99 » Wed Mar 14, 2007 6:12 am
Any special tricks on getting this sucker to fit back in to the gear box ?
I try n I try ... yet i can't seem to make it fit inside and get the speedo to work..
While I am at it.. any theory's on a flickering set of lights and the tempreture gage going up and down like a see saw every once in a while . ?
Speiling mistakes .. me never !
Post by AndrewT » Wed Mar 14, 2007 8:53 am
hm mine fitted straight in really easily, I wonder if yours was damaged during removal or something?
Mine was EA82 originally, I'm not sure if MY speedo cables are different.
Although your car is an L series isn't it?
BlackMale
Post by BlackMale » Wed Mar 14, 2007 10:49 am
I am assuming that its the same cable that came out of the gear box yes?
I can only think of a few things, and you may have already considered.
1) Just make sure that the flat end of the cable is slotting/seating itself all the way into the gear box - it can be a bugger to turn and push down with that sheath on sometimes.
2) I was thinking that maybe it is seating itself in the slot in the gear box however maybe the cable has since broken hence no speedo, have you attempted to pull the cable out and see if its conected at the dash board end?
Other then this i am not sure, sorry.
daza
Post by daza » Wed Mar 14, 2007 1:00 pm
I seem to remember this being a little fiddly, I think i took the cable off the speedo so i could turn the inner from there to get it to seat.
If your lights and gauges vary with your indicators it may be altinator(diodes).
Daza.
:D
Clearwater99
Post by Clearwater99 » Wed Mar 14, 2007 7:39 pm
thanks .. fixed it ..
took it to a mechanic ..
Post by AndrewT » Thu Mar 15, 2007 10:01 am
How did the mechanic fix it?
BrennyV
Post by BrennyV » Thu Mar 15, 2007 10:16 am
AndrewT wrote:How did the mechanic fix it?
all ass and a little class?
Hunter S. Thompson
Clearwater99
Post by Clearwater99 » Thu Mar 15, 2007 7:29 pm
to be honest i don't know .. how he fixed it ..
ignorance is bliss !
Return to “Trouble Shooting”
