EA81T Coughing and missing
Well to recap, had dash light coming on, indicating the coolant sensor, replaced that, also replaced the dizzy cap and rotar, spark plugs and checked for vaccume leaks.
Its still doing it......almost sounds like its not firing when it does is, its under load and compression when it does it.
HELP!
HELP!
have u checked the fuel system??
Dave
Dave
i would be checking the enitre fuel system myself... eg... old fuel lines possibly letting air in... fuel filters... fuel pump.
There has been a lot of times i have had unsually problems which turned into something simple.
Fuel filters are a big thing... can be fine one minute... totally blocked the next.... and this would effect a turbo motor more than a carb motor i would expect.
Dave
Dave
definately check the leads and fuel filter....
a few months ago my car started missing, no power, running on 3 cylinders etc, so i replaced all the leads, problem solved. Then about two weeks ago, the car was coughing and backfiring, it would get to 3000rpm and just die and stall..replaced the fuel filter, and that problem was fixed...
Are you running a good coil? Have you increased the boost?
If you have replaced the leads, try reducing the spark plug gap a little.
Could also be injector related, maybe a bottle of fuel system cleaner, or take them out and get them cleaned.
Finally, I hate to say it but, give it a compression test.
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
- Captain Obvious
jimmy it could be and injector or the coil, i would check the fuel pump 2 i nver had the prob when i had ther car??
- Captain Obvious
my next attack would be the injectors jimmy i gave brad a heap of parts when he bought the car and there should have been some injectors in that stuff if you got it with the car, the injectors that are in there are one a had cleaned which would have been2 years ago??
i may have some injectors here will have a look
cheers
bryan
cheers
bryan
