extractors
extractors
was talking to an ex drag racer, he recommended i got for tuned length extractors- sayed with a 4 cylinder u shud have 4 pipes cumin out and if they r all the same length the airflow, power and to some extent economy will improve. but i can only c 2 pipes cumin out the engine.
New Ride: 1990 L touring Wagon, 2"Lift, Rear Wheel Carrier, Cargo Barrier, Roof Bucket, Replacment Bullbar, Spotties, 27" BFGs
EJ20t sti
01 Sti running gear.
Want :Dual range forester box to suit
Rip:93 L 2 1/4" exhaust, 14" sunraysias, cargo barrier, 32/36weber, king springs, KYB's, 3" lift , 27" rubba. 15" superlites.
EJ20t sti
LOL... do u have a drag car motor in your car? What he told you is probably right on a drag car... wont do anything but cost u a lot of money on your car.
BTW... Milla i just sent u a PM on another subject.
Dave
Dave
- tim_81coupe
In my opinion even length headers aren't as good as everyone makes them out to be. Particularly in a Subaru.
On an EA engine you essentially have performance headers from the factory. The exhaust ports are siamesed, giving one port per head and the stock pipes are only a litttle smaller than this port. This gives relatively good flow while maintaining some back pressure.
For the exhaust you intend on fitting in your "mods to come" part of your sig, you're best off using factory headers and 2 1/4" pipe from the headers back.
Whether or not any of this is worth it on an EA82 of any form is another thing entirely.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Same length headers on my Ej22 made the car sound like a dirt bike... performance seamed un-changed.
Dave
Dave
Am I missing something?
You can't have 4 pipes comming out of 2 exhaust ports.
Most conventional 4cyl motors have one per cylinder and alot of them have pretty basic manifolds which only terminate to 2 or even one exhaust pipe. This is improved by a good set of extractors with an individual pipe for each port on the head. Your friend probably didn't realise that your EA82 boxer motor only has 2 exhaust ports (one in each head). The stock extractors are about as good as you can get really. Possibly can be improved by deleting the CAT (if yours has one) but this really has negligable performance gain but considerable environmental damage.
EZ30 L series - Monsterwagon
Yeah i felt creative last year and made some extractors for my L
I got the plans off an aeroplane site,.. they are designed so that the entire contents of one cyclinder fill one exhaust pipe. So i made it so the contents of 2 cylinders (0.9lt) filled that pipe and made the two 0.9 lt pipes merge in a Y shape. They actually ended up being very similar sizes to the stock headers. (except they were equal length) [PIC attached]
They did very little for power (removing the cat made the biggest power increase but i dont suggest you do that)
The biggest difference was the change in noise, it lost the boxer rumble and didnt sound much like a normal 4 cyl either. More like a race car. (with lost of backfire)
I didnt leave them on for long, i went back to stock headers with 2.25 from cat back and a sports muffer,.. you wont get much better than that.
- 000_0078.jpg (42.55 KiB) Viewed 2244 times
cheers for that guys, perfect replies.
will just go with the catback-hotdog-2"1/4 pipe.
EJ20t sti
EJ20t sti
- waggaclint
