Cig lighter 12V to 5V USB ???
anyone know where I can buy a cig lighter plug (male) that has inbuilt circuit to reduce to 5V with USB socket at the other end ?
One came with a road angel evo but thought a second one handy to wire into a vehicle and thinking may be cheaper alternative than buying another from road angel
- BaronVonChickenPants
Jordan, have looked at jaycar catlog, but may still find in store. A mate reckons he could build one as he is electrical engineer with electronics diploma, half a massage diploma and sells ice cream. Pull plug apart it is a bit more than resistors. PSP huh ? good one
and fredsub, please if you can find your circuit diagram would be a good start. thanks
All you really need is this fella, a cigerette lighter plug, a usb socket and a 470ohm 5 watt resistor
See here for usb pinouts.
Should all come in under $10.
Jordan.
Jordan.
- tim_81coupe
thought it would make a good topic in the manual.....
http://www.ausubaru.com/wiki/index.php/ ... V_solution
meanwhile, I found http://www.mrgadgets.com.au marked them down from $35 to $15, buy three items under 3 kg = free postage. These have an IC in circuit and a LED changing from red to green depending on what is going on.
just so your efforts not wasted I may try build one too , thanks !!
