https://www.dropbox.com/s/zsgx0j5s4zqf8 ... 2.jpg?dl=0
Maybe road safe take L/R from front on instead of passenger is left and drivers is right.
I actually hate this brand. Never good experiences but TRW ( repco) don't make tie rod ends any more apparently
And it gets better.... The wheel bearing kits from Bursons, supplied by Motorgear have the wrong sized seals.
The wheel hubs use a 72mm seal front and back as far as I can tell. The kit from Motorgear has a 72mm seal and a 76mm seal.
Could someone please confirm for me that the standard from wheel hubs on a brumby use the same size seal front and back? It is possible someone put a different front end on this vehicle, but I really doubt it. The bearings they supplied went in fine and the front seal seems good, but the other seal is clearly too large.
