G'Day from Wollongong
Hi all,
I've been an L Series fan for many years, and am currently on my 3rd wagon.
Having done a couple of EJ conversions (EJ - EA Gearbox) for other people, I have started my own conversion.
I'm dumping a manual Bug-Eye WRX driveline into my wagon, and am fairly well down the line with the job.
Build thread to follow...
L-Rex
L-Rex
L-Rex
1992 L-Series Wagon, which used to be EA82 auto.
Re: G'Day from Wollongong
Welcome. Cool, sounds awesome. Look forward to seeing the build thread. Interested to see how you sort out the hydraulic clutch setup, that's always a bit of fun!
Took a bit of measuring, but I worked it out.AndrewT wrote:Welcome. Cool, sounds awesome. Look forward to seeing the build thread. Interested to see how you sort out the hydraulic clutch setup, that's always a bit of fun!
Modified WRX pedal box, cut a slot in the wheel well, fabricated a box and welded it in.
Seam sealed and painted to match.
Naturally, the dump pipe will be wrapped and shielded, as will the hydraulic line.
Some sample pics, I will create a build thread in the near future.
L-Rex
Ah now that is cool. I've only seen that done once before. I played around with doing it myself before I'd seen anyone else do it but I wasn't game to cut through the wheel well and didn't have a lot of time to spend on it.
Instead I chopped up the L series pedal, and a Liberty pedal and welded them together to make a Frankenstein pedal which has been working great.
Nice! Goes to show that there is more than one way to skin a cat.AndrewT wrote:Ah now that is cool. I've only seen that done once before. I played around with doing it myself before I'd seen anyone else do it but I wasn't game to cut through the wheel well and didn't have a lot of time to spend on it.
FYI, I started my build thread in the EJ conversion section. Would be interested to see any pics of yours...
*** EDIT, I just found your build threads, seems you like the more challenging jobs as well ***
L-Rex
Welcome to the forum!
And YEAH!! Another L build
I'm guessing a road hugger?
I'll have to read your build thread
