My tune is a bit on the lean idle side of things and cannot just put the boot into it - have to sort of feed it to get it out of the lean circuit then stomp it
Also got to take it up a steep incline in 1st 4WD HI , light throttle and it willingly ate up the hand size rocky stretch in comfort .
Pretty happy I was not moved to sell my twins. This was with a standard diameter exhaust
 . I don't think you will hurt anything revving it up. Its got a square bore from memory and I personally think the con rods are more then up for the amount of power going thru the engine. The heavy pushrod valve system and large single valves will be the choke point. Better on an ea82, but still large valves. Well done Though Jonno, 90 in second gear. I thought about giving it a go in the vortex the other day but watching how slowly the tacho creeps up in that car I couldn't be bothered waiting
