Update on my Brumby
- TOONGA
Yeah check my vortex threadEl_Freddo wrote:Got it sorted yet? It's been about 6 weeks!
showpost.php?p=234553&postcount=277
Yeah.. why is this in PJ's thread if it was for Jetcar??El_Freddo wrote:That's a good way to keep the order of your threads/different vehicles on the forum etc...
- TOONGA
I got given a 32/36 Weber (true Italian made) a while back. I have meant to put it on PJ as while the ADM34 makes for a fun drive the fuel economy wasn't great.
So I put a kit including the power pump thingie throught the 32/36 and put 60 idle jets, a 145 main and 210 secondary, and left the rest alone as it came off a 2 litre hilux motor.
While the engine isn't quite as responsive off the mark, Im getting suprisingly better fuel economy until the secondary opens
a couple of pictures and yes the bonnet closes without a problem
- Silverbullet
TOONGA wrote: another little update as well
MX5 front Springs conversion to the rear of my brumby
I know this is a big ol' thread dig from many years ago, but I'd like to know more about this!
Are you still running these struts in the back of your Brumby? If so do you still have the torsion bar in there as well? I'm thinking of doing something similar to my wagon (i.e proper struts where the shocks are usually) But don't know which struts/springs to use, or which are small enough in diameter. Also wondering if extra springs on top of the torsion bar will be too much spring
I plan to have some extra gear in the back compared to stock, and if I'm off camping there will be alot more extra gear hanging over the rear wheels, maybe extra springs in that case are a good thing.
- TOONGA
The mx5 shocks are now in the vortex and the original vortex shocks are in the brumby.
The original "shocks" in the MY's are more damper than shock as the torsion bar is the main "spring" device.
this page shows what was done to get a set of aftermarket MX5 springs to fit
showthread.php?t=15851&page=60
I have backed my torsion bar right off so the car effectively sits on the vortex springs.
Having said that if I want to carry more than the legal weight in the back of the brumby I can wind the torsion bar up and load away
The bracket I made is for a 2 inch lift. the same style bracket can be inverted so the rear sits lower if the car looks too high.
hope that helps SB
I did a search on coil overs for the MX5
I think it would be cheaper to use vortex shocks
hope that helps SB
- Silverbullet
Thanks TOONGA, does it help? er, yes and no! So its okay to put coil springs in the rear end where only a shock used to be, keep the torsion bar in place as well. Are the Vortex shocks you speak of from 2WD or 4WD? and are they longer like the L series ones seem to be. Have found a few threads with photos of L series rear struts in MY and they're way up there in height...
- TOONGA
the vortex shocks I have are from my 4WD vortex, they adjustable with lowered king springs. they sit at their lowest point in the brumby and I have reversed the top mount so they sit lower than the MX5 springs ever did.
look at this thread on USMB to see the difference in the shocks available for the L series
http://www.ultimatesubaru.org/forum/top ... n-loyales/
- TOONGA
So I have had a problem with PJ since I bought her the dreaded iron oxide depreciation factor.
Running her up and down the beach hasn't helped. filling the chassis rails with used engine oil helped for a while but rust is rust.
I have a choice try to fix the rust or find a newer brumby to transplant everything that makes PJ what she is.
Recently I was asked if I still wanted to make the transplant happen I said yes but I have a cash flow problem the flow of cash being non existent.
I was made an offer I couldn't refuse.
A 1992 brumby with a broken gearbox and a sad little EA81
Power steering and aircon, they look to be factory but as I understand it that was never an option
She is a little bumpy on the panel side of things but the underneath is rather exciting
Sadly I put her away before I could get more photos.
As for the offer I couldn't refuse, remove the complete power steering system and transplant it into the previous owners new brumby, plus a cash payment from me to the previous owner that will remain a secret.
A problem you say... no power steering for me... nope I say... I have that in PJ and everything else I need in PJ.
All I need is time off and a permission from the boss
another chapter begins
- TOONGA
Yeah it is a great deal and as long as it is looked after, my son will be driving it in 4-5 years time.
I'm not going to drive this one on the beach as much and when I do it will get a damn good wash afterwards.
The power steering conundrum gets me as well. I know a guy who swears that the GL brumby came with aircon and power steering, yet I've seen them with one, both or neither.
Trying to organise the time and money to get this swap done done is my next big hurdle.
