leaking camshaft seals on 98 outback
hi all , about a year ago i did a top end overhaul of my 1998 outback , the heads were rebuilt and skimmed by my local head shop and i put it all back together, just recently i realized that the engine was smelling of burning and once i removed the belly pan found an oil leak towards the front of the right hand side of the engine seemingly coming from the lower camshaft seal then dripping on the exhaust, after checking it out i noticed the other side was leaking in the same place but just not as bad. obviously its quite a job to replace those seals and the rocker cover gaskets so i was wondering if there was any reason for them leaking so quickly (after 12000kms) , did i do something wrong ? i don't think i used genuine seals/gasket set due to cost, any thoughts much appreciated, cheers
- FROG
2.5 litre?
cam seals are only 9 bucks retail
$7.18 to AUSubaru members
+1Yep the aftermarket cam seals are prone to failure.
The original seals work a treat.
Or at least source Japanese made, in which case just go through FROG.
Damn good price at whats quoted. Its a shame the labour to replace them is massive
Some of the seals,gaskets and o'rings in a gasket set are just junk from experience. Some are really good, particularly when they are NLA genuine.
+1Also be sure to prime the seals with a rubber or plastic grease so they're not running dry on initial start after fitting.
This makes a big difference.
J.
- Suby Spanner
