Hello, I have a n/a MY98 Sportwagon and I am finding mixed msg's on the net re upgrading/converting to WRX parts. There is a lot of info re sedan's however it seems that wagons are little different?
Can someone give a clear answer or link to more info please?
I am really interested in doing the sway bars, suspension to coilovers and if I can swap my standard front discs for WRX ones that are bigger and slotted for extra stopping power?
Thank you in advance.
Rj
MY98 Sportwagon to WRX parts conversion compatibility
I'm 99% sure suspension front and rear are interchangable without issue. If you go with the WRX brakes make sure you use the brake booster too. A complete system swap is much easier to do and get right than mix and matching bits.
Sway bars etc should bolt straight on.
Try asking on http://forums.nasioc.com/forums// for the answer. Of course start by searching to find what you're looking for before asking the question - you'll get more cred with current members if you've already done a search
All the best with it!
