Brumby EJT project help Unknown parts?
OK, Got excited and made another rookie mistake... When starting work on an unfamiliar motor always check it turns over by hand.  Even had it off the stand and the new flywheel and box on...
The quote, "You're a god damned genius Gump!" comes to mind.
It was frozen but with a little oompf it now turns abot 180 degrees. Thinking it has either a frozen valve (its humid in bundy and has been sitting possibly 2 years) or the guy who owned it, an apprentice at bundy subaru, made a mistake putting on a new timing belt... Tomorrows adventure now though. Beer and a zombie movie are in order...
turns out the spark plugs were only in 2 turns... So over the last 3 years of sitting in bundy (two floods) the humidity has got to the inside wear faces of the engine and given them a nice coating of oxide dust/rust The bores look ok after turning it over and the vlave seats i can see through the plug holes look ok too. (except for the orange colour) Am about to order a full gasket kit and when i pull it down, rings and give it a freshen up... Cam faces etc all look like new.
Yeah.. if that water has got inside and it's been sitting for a while, I'd recommend a rebuild. Sounds like it's going to be a big project car. We want pics along the journey
So I lost a little time on the brumby fixing a mates off road buggy... Back to it now.  I have since had delivered a full gasket kit for the EA and a manual that supposedly covers all 1.6 - 1.8 motors from 79 to 94.. Unfortunately no mention of the turbo version.
My question is, Are there any tolerance differences between turbo / non turbo? piston sizes the same? ring size and type?
Have now stripped the EA82T down to a short block. everything is full of sludge and surface rust. Thankfully no damage to the bores just the faintest score marks from forcing it to turn over. Having stripped a few motors before I am thinking this one has very low kms. original bore size, no lip whatsoever, cam faces are all like new... Only Issue is that whoever first owned it didn't believe in coolant and all the water jackets are full of dust and crud. Bit worried about re-tensioning some of the head bolts in the water jackets back up. Should be ok though. Anyone know the part no for rings on an EA82T? I want to disassemble, clean and reassemble as I go...
I'm wondering if we could get a Mod to change the title to "Brumby EA82T..." as I get excited with the "Brumby EJT..." title.
Don't get me wrong, I enjoy reading where you're going with this build, just that when the title pops up in my email updates I'm basically keen as mustard to read another EJt Brumby build
