How to properly adjust an auto choke EA81
Post by El_Freddo » Thu Mar 05, 2015 8:32 am
G'day,
I'm trying to get Redback running right as I'm sick of taking 5 minutes to cold start it without the choke.
I've removed the piece of wire we used to keep it open, adjusted it so that it was closed when cold - it started great this morning! But once hot the choke still remains partially closed rather than fully open - this is after a 10 minute drive.
How do I adjust this to get full movement for the best of both worlds? Keen to get this sorted ASAP.
Willy Fisterbottom
Post by Willy Fisterbottom » Thu Mar 05, 2015 9:32 am
What carbie are you running? I'm guessing you're running a manual choke carby with no cable???
Post by El_Freddo » Thu Mar 05, 2015 11:02 am
Yeah sorry,
Hitachi, auto choke, no cable. Same as the EA82 carb auto choke but the smaller version.
Post by Silverbullet » Thu Mar 05, 2015 5:10 pm
I have scanned the auto choke adjustment section from one of my factory service manuals hopefully it's the right choke model, but they're too big to attach on here. Even compressed they're too big :(
So I uploaded it to this file hosting site, if you trust those sites here it is:
Page 1:
http://s000.tinyupload.com/?file_id=947 ... 1396367629
Page 2:
http://s000.tinyupload.com/?file_id=217 ... 5387557187
Page 2 got a little fuzzy because the book is so thick it's hard to squeeze it into the scanner :rolleyes:
tambox
Post by tambox » Thu Mar 05, 2015 6:29 pm
As long as all the parts of the choke are working, they are relatively easy to set up.
Make sure the pull off diaphragm is set up correctly and works.
I can be simpler to set the choke flap so it is fully open (just) when the motor is warm and the diaphragm is also pulling it open.
Make sure the choke coil is earthed properly.
It depends on how cold the air is when you start it how hard it will close, but make sure the diaphragm does it job, or you will never get it correct.
L serious, still.
Willy Fisterbottom
Post by Willy Fisterbottom » Fri Mar 06, 2015 10:31 am
The best Hitachi manual ever written is right here downloads.php?do=file&id=132
Return to “Trouble Shooting”
