But yes new ECU and loom, to make things easier on that front and the engine for its bolt-ons as I suspect its quite cooked. Its already proving useful, discovered the difference between the "standard" and "hydraulic" timing belt tensioners today...I've already bought a standard type TB kit, so the good engine will be converted to standard tensioner using the one off the cooked motor.
Props to TheInterceptor for pointing out the substructure in the block that unbolts to swap between tensioner types, saved me a lot of frustration and wasted time/money.
Got the new loom stripped down today and virtually ready to go, will test in the Liberty first then out comes the EJ for some TLC!
Starting with a good wash and degrease! Much needed after a brief career as a paddock car
Then timing kit, external oil seals, water pump and other consumables
Might get a bit crazy with some spray cans too...red timing covers sounds like a good idea...might go full STi impersonator and go red intake manifold too....maybe...
Watch this space!
I'll make sure I have my camera with me this time!
