low rpm misfire on 97 outback
a couple of weeks ago i bought a 97 outback very cheap that was running pretty rough, (misfiring badly)  i checked the error codes and it had two, a 22 knock sensor and a 32 oxygen sensor, i started with the knock sensor which i replaced but eventually found a broken connection on one of the multi-connectors, repaired and cleared ecu codes and the car ran great
 until it was warm , it has a low down misfire and seems short on power but is coming up with no error codes now (the o2 sensor fault has disappered) , it does run alot better than it did thou. is it worth replacing the o2 sensor?  i have already replaced the plugs , leads, fuel filter , help much appreciated, thanks
						got stuck into checking the tappetts here's wot i found:
cylinder 1 inlet 0.18mm and 0.15mm
exhaust 0.23mm and 0.23mm
cylinder 2 inlet 0.14mm and 0.15mm
exhaust 0.21mm and 0.23mm
cylinder 3 inlet 0.20mm and 0.18mm
exhaust 0.26mm and 0.24mm
cylinder 4 inlet 0.18mm and 0.18mm
exhaust 0.23mm and 0.25mm
according to my haynes manual inlet should be 0.18 to 0.22 and exhaust 0.23 to 0.27 so most inlets gaps are too small and most exhausts are pretty close to , never done these shim tappets before, is it hard? are the shims available/expensive ? and the manual says i need special tool as well
The OEM 97 legacy manual lists in .20-.22 ex .25-.27.
The clearances you have will not give you the problem you are trying to sort out. They will reduce the "efficiency" of the engine by "x" amount.
The shims are easy to do, with the motor out:D
They are fiddly to do in the car, I use a flatbalde screwdriver and magnetic pick up tool.
The pain is, you have to take them out, measure them, work out what size you need, then fit them. Not much fun if you need to drive the car to get the new ones = double remove/refit.
They are not cheap, try the wreckers or a Subaru motor rebuilder.
But once they are done, provided everything is running well, they won't need doing for while.
Find the problem before you do the shims.
Any white condensation/sludge under the rocker covers?
L serious, still.
