WRX-Ute ...
- Bantum
WRX-Ute ...
Just because I can :
For those who want a more 'sportier' version based on the yet to be seen WRX ...
Cheers, Bantum ...
Edit : Aw crap, photo buckets f*#! up again - will have to come back & fix links ... :/
Cheers, Bantum ...
How about a BRZ ute ? Body length is about right, tails could work shape-wise, and best of all RWD ��
- Bantum
BRZ details ...
Speaking of the BRZ, while searching for more background info I came accross some interesting photos :
See here for info on the BRZ Chassis ...
Which no doubt should help in the fabrication department ...
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
More Vroom than a ...
Ahem ... you'd be nearly lying down in this version, as it's design to go fast ...El_Freddo wrote: ... Cab height it too low ...
Hence the low drag coefficient going on ...
dfoyl wrote: ... How about a BRZ ute ? ...
That's exactly what I have in mind for the under body of this version ... !
I've just put a larger body over it as the BRZ one is way too small ...
P.S. - I'll have to add a person to it to get a better perspective of scale ... :ninja:
Cheers, Bantum ...
- Bantum
Driving Positions ...
Here are a few examples ..
The granny :
The Crash Test Dummy :
The F1 :
Now that would be interesting ...
+ a few others :
Like the 'Pimp' one ...
Will see what else I can find ... :0
Cheers, Bantum ...
The granny :
The F1 :
+ a few others :
Cheers, Bantum ...
- Bantum
Fruity ...
Found this while searching :
Not sure I like it, but interesting nonetheless ...
Edit : Damn lost the link to original, will try & re-locate ... ;(
Here is the one I had in cache :
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Yep I'd agree with that it was probably photo chopped from a Holden ...
P.S. - found another interesting concept :
Based on the Chevrolet Montana, more details here ...
As to my proposed beast - No progress on modelling it yet, when it get round to it ...
Ciao , Bantum ...
Ciao , Bantum ...
- Bantum
Go Kiwi style ...
Hmm - someone else had the same idea :
More details to be found here : http://www.crowesport.co.nz/motorsport.php
Cheers, Bantum ...
Cheers, Bantum ...
^ That's pretty neat! If something like this were used I'd like to see a bit more tray space forward of the rear wheel. Other than that it really looks the part!
That chev concept looks like a big brother version of what i reckon a modern day Brumby would look like - but without the sporty body kit and with more ground clearance.
Yeah thats definitely cool One of the best ute conversions I have seen. Although the rear part of the cab looks just a bit too big/long - but I guess thats the shortest they could get it by using the rear section of a sedan.
Maybe thats what I should have done instead of trying to get WRX gear into my Brumby
That might be my next project with my RS wagon if I ever finish the Brumby.
Or maybe my Mitsubishi Legnum wagon like this :
- Bantum
More Audi Ute ...
Yep :like: it ... ... ( Doh - you have to be member to see what's in that link )
Also found some more on this beast :
More to be found here : http://www.agwheels.com/customers/Sort% ... 7e3_7.html
Finished in nice blue - Also note the rear hatch is similar to what I was thinking ...
Cheers, Bantum ...
Cheers, Bantum ...
