Post
by Silverbullet » Sun Jul 06, 2014 12:50 pm
Not specific to the twins, I have a carby with one on it. It's from an early-ish model I think 1983 or before. My wagons 81' engine had one on it. Basically get's switched power with the key, must be when you turn the key off the little plunger inside clicks in and blocks the fuel flow somehow.
What do you want one for? I think you can buy new aftermarket solenoids, the old ones suffer from the single wire cracking right where it meets the base of the solenoid, copper eventually fatigues and the wire drops off.
