tool for EA81 #1 head stud nut torquing
Post by steptoe » Wed Jul 02, 2014 12:52 pm
there is or wuz a picture in here of a tool that helps , ring one end, 90 degree bend, about 3", nother 90 bend then a 1/2" square drive hole for torque wrench....
just dropping lunch crumbs over a catalogue for Litchfield Engineering P/L, Croydon Park , SA Part no E3324 11/16" suits Ford OHV motor. These were made in Adelaide, so could likely be an abundance of them near Silverbullet around fleas markets, garage sales, swap meets etc. Save self grief looking for them in phone book or 'net. Cattledog is a bit musty and dusty - from 1970 !
Another tool that looks like it may also do the job is like an 11/16" ring spanner, that instead of a handle leading to other end, is a stumby number like two 20c pieces side by side, the second being 1/2" drive hole once again, part # E3344 another specialty tool to suit Holden EJ Sweephead
The one I borrow is a Sidchrome made tool and is structured more like the tool at most left,
, and was ground down a little to fit EA81 #1 head stud nut :)
11/16" = 17.4625 millimetres
Post by Silverbullet » Wed Jul 02, 2014 2:26 pm
Made in SA eh? Who'd have known there could be one near me :) In abundance I'm not so sure. Some interesting shapes there, but the instructions for my torque wrench say not to use a tool like E3344 in that catalogue.
Post by steptoe » Wed Jul 02, 2014 4:18 pm
oh, for fear of altering final torque achieved I suppose. Lucky for me I used the other one :)
scratch the stumpy thing then !
Post by Bantum » Wed Jul 02, 2014 10:14 pm
I found another method :
As described here : http://mthobby.pcperfect.com/ch601/chengine4.htm
This is a cut down articulated 17mm socket ... :)
Cheers, Bantum ...
Post by El_Freddo » Wed Jul 02, 2014 10:23 pm
Dad did something like this for my EA81 - so it's now a part of the tool kit!
Post by steptoe » Thu Jul 03, 2014 8:25 am
I did something similar for EA82 head bolts, just not a wobble socket, must find and try on the 81 then...
Post by El_Freddo » Sat Jul 05, 2014 10:00 pm
But EA82 bolts are easily accessible... I'm confused!
Post by steptoe » Sun Jul 06, 2014 8:20 am
EJ convert has forgotten. Maybe EA82T heads are different, you never had one eh ? :D
I had trouble the moment I turned Japanese - what with a handful of tools, sockets in 1/2" drive only -all I need for an old Ford - what's this 3/8 and 1/4 drive stuff for ?? :)
Still can't find a 1/4 drive 17mm socket to get in at two of the EA82 head bolts, so use a 3/8 drive 17mm with its shoulders rounded off just like the pic above
That tool or very similar is also in the A82 manuals, must be for a reason ?
