What Radiator to Get
I've cracked the radiator inlet pipe (plastic), so now I'm looking at getting an all alloy one (no silly plastic end tanks!) I've been told to get an eBay one but was wondering if anyone can recommend a seller. Has anyone bought a radiator from eBay? What was your experience? Would you recommend that seller?
Thanks Jan, I ended up getting this one:
Golpher Full Alloy Radiator | eBay
Golpher is very popular on other forums & its an Aussie seller with 99.5% positive feedback. He was very co-operative answering my questions & its a definite match for my Foz. The same mounting points & fan points plus its 10mm thicker so should fit my cooling requirements nicely
UPDATE: This is the wrong radiator for a '97 Forester!
The fan mounting holes/brackets are in the wrong spot. This suits a '98-'02 Foz. After several emails back & forth, we realised this. He is now getting me the right radiator, an all alloy version of this:
http://www.ebay.com.au/itm/190859030434 ... 26_rdc%3D1
Note the mount is just to the right of the inlet pipe (see 3rd pic for explanation). This is like the one on my '97 model. Later radiators apparently have the mount directly under the pipe.
Be sure to check which yours is before you buy this or any other radiator!
The eBay vendor has been very co-operative & is even arranging return post himself
Yeah, he's been very helpful. Thoroughly recommend him!
Can't have both sets of mounts on the one radiator as one set of the bottom mounts would get in the way of the other being ~15mm higher, Good idea though
No need, he's replacing it with the one I need. I wouldnt like using zip ties to put my fans on, esp when there is a radiator with factory mounts. All will be good
