Brumby Brake Caliper Pistons
Anyone out there know where I can pick front brake caliper pistons for a 91 EA81 Brumby 4x4 ute.
specs indicate they are same diameter as L Series EA82 which should be more plentiful. Don't just limit your search to Brumby, but I recall the brake pads changed, as did rotors ? for the MV 85 that started with MY built in later half 84. Can't say if the piston changed with the pad change. They went from DB326 to DB426 from memory
From memory, there is a casting number (like 2101, 2107, 2109, etc) on the top of the caliper near the handbrake arm. Just pop in to your local car wrecker and see if he has one to match, or ask anyone on here if they have one?
