If I go ahead with plan 2006 - Project Cheap Grief will make way for EA82T powered Brumby, and braked by its disc rear.
I will have a rear sway bar and swing arms with the brackets salvaged off the GLTA, thinking of cutting the sway bar down to fit across the Brumby correctly and make up after market sway bar style mounting brackets to firm up the rear handling and not much care for articulation - already got a thicker Selby ? 25mm front bar
Whiteline used to do a BSR241 to suit bolt on for MY, dropped production likely due to no interest, maybe due to the cost more than anything, or, not many 30 year old MY's about no more.
Anyone done an L rear bar to MY ??
I may also have a turbo front engine cross member up for grab$ if I go ahead with plan
L rear swaybar on MY
- Silverbullet
I made some brackets to fit an L sway bar to MY rear arms, just need welding on.
I doubt I'll use them, are they of any interest to you?
