99 forester to 05 ej20 transplant
scott64
Post by scott64 » Mon Apr 14, 2014 11:02 pm
Hi guys new to this forum.Recently bought 99 forester LX ran it around town for a week, all seemed fine. when i took it on the highway it started to overheat bubbles in radiator and very strong smell of exhaust and a lot of pressure in radiator. Suspect blown head gasket or cracked head. spoke to the guy i bought the car from, who had an 05 model he was wrecking and assured me it would fit and it does fit just doesn't run, i kept the old 99 intake manifold too keep the wiring the same sensors and such. both engines seem identical apart from the 05 has a cam shaft position sensor and the 99 doesn't.
So end result is i have car in shed with 05 engine that wont run:(, is there some way to get this to run that doesn't include new ecu and a rewire or going back to the old engine and fixing what ever its issue was.
looks like Ive done something terribly silly taking the route that i did, Not enough research (none) seemed like a good idea at the time.
I hope there's an easy fix but i suspect there's not any help much appreciated
Post by Gannon » Tue Apr 15, 2014 6:01 am
Hello and welcome to AUSubaru
If the 05 model engine is from a Forester it will be a 2.5L.
Can you post a detailed photo of the cam sensor on the 2.5 and a photo of where it isnt on the 2.0?
scott64
cam sensor
Post by scott64 » Tue Apr 15, 2014 7:36 am
gday mate hey thanks for your help. both engines have ej20 on the block, which i assume means 2.0 litre[ATTACH]4413[/ATTACH]
[ATTACH]4414[/ATTACH]
top pic 99 with rubber bung
bottom 05 sensor with nowhere to connect.
didnt see the car but am told was 05 forester will check on that
05 ej20.jpg (101.03 KiB) Viewed 4208 times
99 ej20.jpg (96.88 KiB) Viewed 4209 times
scott64
Post by scott64 » Tue Apr 15, 2014 8:03 am
05 is out of imprezza
Point
Post by Point » Tue Apr 15, 2014 8:59 am
did you change the pulley on the crank? The one the timing belt runs on, that the crank angle sensor reads. there should be a different number of teeth if it's anything like the swap I did.
98 Forester GX
02 Forester XS Luxury
scott64
Post by scott64 » Tue Apr 15, 2014 9:28 am
No mate was just heading down that path to look at timing. just taking both timing covers off to see what i find.
did you just change the crank pulley or both cam pulleys as well ? would have thought they would be a set
Point
Post by Point » Tue Apr 15, 2014 10:00 pm
Hmmm. I did the swap a while ago, so I can't remember if I changed the cam pulleys. I think they were the same. I will have a look tomorrow.
BTW, mine was a 92 EJ22 into a 98 Forrie.
98 Forester GX
Post by El_Freddo » Wed Apr 16, 2014 1:11 am
Is the '99 Foz the one with the ECU mounted on the driver's side of the engine?
If changing the timing pulley on the crank to the one that came off the car sorted the issue for Point, I'd be swapping the entire cam belt setup to the original EJ20's - unless one is a SOHC and the other a DOHC (Single/Double OverHead Cam)... Then just swap the crank pulley/gear and see how that changes things. You could do a test fire before you put it completely back together incase that doesn't work!
scott64
Post by scott64 » Wed Apr 16, 2014 11:11 am
yep looks like the crank pulley is the culprit.Looked down through sensor hole appears to be different. haven't had time to do the job yet. will keep you posted as to how i get on.
Thanks for all your help cheers.
taza
Post by taza » Wed Apr 16, 2014 7:47 pm
It should be mate. Im running a Outback 2.5 in my 01 Foz this way. Had to swap the crank gear. I just left the xam senaor unplugged as the computer for the foz 2.0l doesnt need a cam sensor.
scott64
Post by scott64 » Wed Apr 16, 2014 8:56 pm
yep job done up and running. 05 crank pulley had 6 teeth 99 had like 70.
Cheers guy thanks for all the help!
scott64
Post by scott64 » Wed Apr 16, 2014 9:02 pm
yep job done, the 05 crank pulley had 6 teeth the 99 had about 70.
Cheers guy and thanks for the help!
